Greg Sullivan is a non-member guest and is in no way affiliated with InterNACHI or its members.
In California, my last two homes had those pesky anti-siphon adapters permanently mounted on each outdoor faucet. They are supposed to prevent water from flowing backward if the city water pressure were to suddenly drop. The backflow could supposedly lead to contamination of the water supply. These one way valves always leak and if you turn off the faucet while the garden hose is pressurized, the anti-siphon valve will discharge the pressure in the hose through some vent holes. This is when you will get a face full of water as the valve vents.
Do any of you know if these things are required per some state or local code? If I remove them, what is my liability? Do you inspect for these during home inspections? Is this just a California thing? Thanks in advance for your feedback. Greg Sullivan / Canyon Lake, CA. |
Yes they are required in CA (CBC Chapter 6).
It's just like any other code requirement. Once you've moved in, you can do what you want. When I inspect your home for a potential buyer, I will tell them that they are missing and recommend replacement. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Hey Greg,
It is not just a California thing. They are everywhere. An anti-siphon device (or vacuum breaker) prevents unsanitary water from being pulled back through a garden hose and contaminating your water system. Otherwise known as a "Cross Connection" I always look for them and report if they are present or not. I believe most building codes require them on homes built. But you would have to check with your local municipallity. |
They are required where I inspect, at least by the city for sure, and I report them missing if so.
When I bought a house in Mt. Clemens, MI (Macomb County) I could not close on the house until the city inspector saw that they were installed. He also required a hand rail to the front porch before I could close. (1 step then step up onto the porch while holding the storm door open. He had me install the hand rail behind the storm door. I installed it while he watched. After he signed off on it he watched me remove it & put it in the trash. We all laughed. He said he would have done the same thing.)
Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
Mine do not vent water like that, they do make some strange noises at times while in use though.
B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I do not think that they are that concerned with your water system being contaminated, but it does get exciting when you contaminate the public water system.
Thanks for your feedback.
About one year ago, I tried to remove one of those anti-siphon valves from a back yard faucet. They are threaded onto the faucet and locked on with some type of pin that jams down on the threads. The pin will not let go of the faucet's threads until it is drilled out. Of course, drilling it out ends up damaging the faucet's threads. That forced me to replace the faucet with a new one. If there's an easier way to remove these anti-siphon valves - I haven't found it - yet. Thanks again, Greg Sullivan / Canyon Lake, CA. |
I thought they were put on with Superglue or Gorilla glue.
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Usually that pin that you speak of is an allen headed set screw....and it is usually corroded all to shiite. I used to just turn the water off, hack the entire hose bibb off and solder a new one on.
As for them protecting their water......my Arizona Contractor's License requires me to install PVB backflow protection on all the irrigation systems I install(ed). The city's stance was: YOU need to install this backflow prevention to help us guarantee the water we provide will not be contaminated, keeping the customers safe. LOL Those hose bibb asv's are useless anyway, most of them aren't working right anymore...but they sure do look super! Wanna know how we explained the need for cross connection to our clients that fought us on the price? |
yes.
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
LOL
They used to ask me all the time, how the hell can water from the lawn area get sucked into my home, carrying with it all the pesticides/herbicides/fertilizers and dirt etc? How can it happen? Why do you need to charge me 300 dollars to install this thing that I didn't have when the house was built? Why? How? I would say here is one scenario: Crack house down the street explodes...causing 2 or 3 other houses around it to explode causing a raging inferno requiring 15 fire trucks.....they all tap into a hydrant, causing the water pressure and volume to all but disappear....the force of the fire engines pumps is so great that it literally sucks all the water OUT of the piping in your home.....which creates a massive suction, thereby sucking the water out of your sprinkler system mainline, which then suckes the water out of 300 feet of lateral lines...of which the sprinkler heads are attached.......the suction is so great that it sucks bits of dirt and fertilizer etc through those tiny holes in your drip emitters and the small orifices of you lawn heads...all the way back into the potable water system. When the water pressure comes back up after the fire is put out.....the dirt/fert/herb/pest is in the system and will cause sickness disease and overall poor health. As they stood there looking at me, dumfounded, trying to decide if I was full of it or just crazy or maybe even telling the truth...I would say : "Besides, if I don't install it, I could lose my Contractor's license!" True Story |
Thanks Tony. That gave me a good laugh.
http://www.abpa.org/originalsite/pnw-all.htm
Nice, Brian. Thanks.
Now that I have stories, I can start calling out the lack of anti-siphon devices on those exterior faucets. NACHI 2005 U.S. Member of the Year
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| Proposed Class Action Settlement "Sears" Anti-tip Device | mcyr | General Inspection Discussion | 3 | 11/8/07 7:18 AM |
| What the heck is this device!! | dmacy | Plumbing Inspections | 11 | 3/18/07 10:18 AM |
| A/C location of expansion device vs line temps. | bking | Inspecting HVAC Systems | 9 | 5/29/06 5:16 PM |
