I have an anti siphon, frost proof faucet that leaks through a hole (vent?)in the stem when the water is turned on. Can this be repaired or must the whole unit be replaced?
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Yes, the anti-sipon valve can be repaired/replaced. Rubber washer inside. Find out make/model and find replacement washer.
Joe is correct and its a common thing found on home inspections. Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
The only time I am able to find it is if there is pressure on the sillcock...like a water pressure gauge for example.
Jeff Jeff Wicklander Corwick Home Services Join my business on Facebook
| Frost Proof Hose Bibs | inxil | InterNACHI & RealMatcher Blogs | 0 | 2/14/10 5:10 PM |
| Roy the proof you asked for | wdevries | Canadian Inspectors | 55 | 7/8/08 11:30 AM |
