When I test both exterior faucets for pressure, one of them had water coming out underneath the Anti-Siphon valve cover. Any thoughts on this? First time I have had one do this.
Hi Charles,
I have seen them do that, the problem is that the washer/seal has failed or is crudded up, rebuild kits are available for most of them very cheaply $5 - $10 write it up as in need of repair Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Thanks Gerry...I appreciate it. It does not leak when nothing is connected to it, but if I put the pressure gauage on and have a little back pressure it leaks.
Actually replacing the valve is very simple, once the plastic cap has been taken off the valve stem can be undone and the main seal replaced. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
homebild is a non-member guest and is in no way affiliated with InterNACHI or its members.
I will have to disagree as nationally certified ICC residentail plumbing code inspector with Gary Beaumont's comments regarding 'replacing' and 'rebuilding' atmospheric type vacuum breakers.
While such 'vacuum breakers' might be able to be rebuilt, they will certainly lose their listing and labeling by their manufacturers if so done....and therefore become an illegal appliance if continued in use unless recertified by the 3rd party listing and labeling agency. That said, the ONLY correct action is this case is to replace the entire hose bibb completely so that the new one is listed and labeled for its use. 'Rebuilding' is not code compliant under the IRC plumbing code provisions even in Florida unless Gary Beaumont can show otherwise. What I see is a code violation and the entire hosebibb assembly needs to be replaced not "repaired".... |
http://www.woodfordmfg.com/Woodford/.../17CATALOG.pdf
Here is the drawing and the listed repair kit. pn RK-17 |
I can find nothing in chapter 29 of IRC 2006 that suggests that repair of backflow preventers is not permitted, and all the manufacturers that I have looked at this morning have repair kits available. I will be very interested to see the code that you mention Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
I don't see how the repair of any "listed" component with properly listed repair parts by qualified persons would invalidate the listing of a device-----otherwise how could you fix anything in the electrical, hvac or plumbing world?
| TPR valve | acox | Plumbing Inspections | 19 | 5/27/07 12:36 PM |
| Backwater valve in new homes? | ccrooker | Canadian Inspectors | 16 | 11/28/06 7:47 AM |
| Moen Shower Valve - No Retainer Clip Slot | Zemke | Plumbing Inspections | 7 | 9/24/06 10:02 PM |
| Tankless and TRP valve | jtroth | Plumbing Inspections | 14 | 8/8/06 12:09 PM |
| Pool inspections/ valve check | dbucknavich | Ancillary Inspection Services & Additional Topics | 1 | 6/21/06 3:33 PM |
