Old 6/12/09, 10:18 AM
Bob Elliott's Avatar
Default Any ideas what this garden hose is for?
Found this in crawlspace of split ranch. 1962 and connected to a galv supply pipe.
Pipe appeared to head from outside front bib to rear kitchen sink area.
wall it enters is other side of 1/2 bath and wall after that contains stack pipe in basement utility room.
Thanks for any educated guesses.
I need to go inspect for now.
Find an InterNACHI certified Montana Home Inspector (and anywhere else in North America)
Old 6/12/09, 11:00 AM
gcavallo's Avatar
gcavallo gcavallo is offline
Default Re: Any ideas what this garden hose is for?
Was it used to build pressure to move the water -> inward? Was there an area outside to "WASH the tractor? Are you saying that someone is consuming this water even though it flows through the dissimilar piping? [galvanized and copper]. What say you?
Old 6/12/09, 3:15 PM
I did not have time to trace it out unfortunately.
Was hoping for some ideas.
Old 6/12/09, 3:41 PM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
WAG - needed a hose in back to water the plants?
Old 6/12/09, 4:28 PM
What kind in crawl space.
Magic mushrooms.?
Maybe under the old oil tank at the other end.
Old 6/12/09, 4:40 PM
Michael Larson's Avatar
bob, I'm unclear from you description.
Is that hose under pressure at all times?
If so, write it up as non standard material used for pressure piping.
Garden hose is not intended to be constantly pressurized and certainly not for potable water use.
Michael Larson
Hudson, WI
[/I]
Old 6/12/09, 4:42 PM
rmaday's Avatar
Magic mushrooms.?
Um, Bob...
From your pictures, it doesn't appear that the hose terminates in the crawl. Actually, you said you didn't have time to trace it out.
Logic says that if it did indeed terminate in the crawl, you wouldn't be wondering wher it went.
Old 6/12/09, 4:46 PM
Well, like I have seen in the past, they wanted an outside hose bib and could not afford the plumber, and have also seen where a washing machine was added and fed with a hose.
Plumbers are expensive.
Old 6/12/09, 5:49 PM
Where it goes into the wall I may need to go back and trace out as client two 5 or 6 year old girls were in there crawling around with me.
Very distracting at the time and I was looking at other issues more attentively.
Wish I tracked it better.
Hose goes into wall behind a half bathroom with sink on opposite wall
Joists connections ,tar paper foundation repair , oil tank, etc.
Looks like I need to go back on walkthrough.(hate when that happens
Old 6/14/09, 9:30 PM
Does it really matter what it is for? Yes, I would be very curious and would have probably looked for the other end for a couple of minutes, but in the final analysis, I would just write it up and make it a "red" comment.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Entran II Hose Class Action Suit jbushart Inspecting HVAC Systems 0 3/3/09 10:46 AM
bonding main hose bib with pex Scott Schultz Electrical Inspections 5 6/21/07 11:39 PM
Hose from copper piping.. gbrasseur Plumbing Inspections 9 4/29/07 8:53 PM
Garden Hose thejnicki Inspecting HVAC Systems 8 9/24/06 7:00 AM
