Main water supply on left with regulator. 2nd. pipe could have been mistake and/or future line for?
But there is a T with another shut-off. Would a plumber have left the valve behind for no reason? Any ideas what it could be for? Steven Wessler SpyGlass Inspection Services, LLC Serving The Lake of the Ozarks, Missouri INACHI: 09021806 www.spyglassinspect.com |
| Need a home inspection in Alaska? Check out InterNACHI's listing of Alaska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Sprinklers?
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle |
Gary,
That was a thought, home was built in 2,000 and did not see other homes in the area with sprinklers. Also I questioned a 3/4" line but could have just been following up with the same material to exterior. Steven Wessler SpyGlass Inspection Services, LLC Serving The Lake of the Ozarks, Missouri INACHI: 09021806 www.spyglassinspect.com |
Christopher,
Not sure I understand? Just stubbed through wall with no valve on pipe. Steven Wessler SpyGlass Inspection Services, LLC Serving The Lake of the Ozarks, Missouri INACHI: 09021806 www.spyglassinspect.com |
... Or exterior hose bibb that froze/burst and was eliminated? 3/4" would be appropriate for either.
Jeffrey,
No signs of damage. Tried the snake camera and the line did a 90* downturn and the lens could not get by. Steven Wessler SpyGlass Inspection Services, LLC Serving The Lake of the Ozarks, Missouri INACHI: 09021806 www.spyglassinspect.com |
Possibly a failed water main? Whatever it is, It is abandoned, probably for a good reason.
Auxiliary water line or system like sprinklers or pool.
montrealbuildinginspectionservice.com montreal-home-inspection-services.com home-inspections-montreal.com homeinspectionsservicesmontreal.com ROBERT YOUNG'S MONTREAL HOME INSPECTION SERVICE INC. Certified Inspecteur Professionnel Certifié en Bâtiment membre de InterNACHI ACHI , Chapters - OntarioAchi et du M.I.C.Q (CPI) - (CHI) OFFICE (514) 489-1887 MOBILE (514) 441-3732 TOLL FREE 1- 855-819-1816 |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Pellet stove help | chellickson | General Inspection Discussion | 23 | 8/19/10 1:23 AM |
| Is this allowed? | belliott | Plumbing Inspections | 4 | 7/15/09 6:40 PM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
