Old 3/31/08, 6:06 PM
Bob Elliott's Avatar
Default Any one know their holes?
When checking out a basin my client asked what are those two holes for?
I said , opps I don't know.
Anyone?
outside the garage with grill cover.
Old 3/31/08, 6:14 PM
Marc D. Shunk's Avatar
Banned
Default Re: Any one know their holes?
My guess would be trap primer inputs if that's a floor drain, or a place to put hoisting rigging if that's a concrete catch basin.
If it's neither of those, you could say that I don't know my a55 from a hole in the ground.
Old 3/31/08, 6:40 PM
not familiar with that term Marc
Old 3/31/08, 6:44 PM
Dale Duffy's Avatar
That is what it looks like to me also Bob.
The holes are for two metal pins to be inserted in them for the top of the manhole to be lifted from the truck and placed.
If that is the fact, the holes should of been mortared when the top (metal portion) of the catch basin was installed.
Old 3/31/08, 6:45 PM
Banned
What term?
I am curious what we're looking at here, since it lacks perspective. Is this a floor drain, or something bigger like a catch basin? If it's a catch basin, those holes could also be for witness pipe drains to indicate that the primary standpipe style drain (orange-ish color) is clogged.
Old 3/31/08, 6:53 PM
Marc outside the garage .
If you look at the right side you can see it is for storm water.(grill cover)
The driveway was down hill.
Thanks for the reply and I think Dale is right on this one.
Old 3/31/08, 7:26 PM
Dale might be right, but when I see lifting holes I see something like this.
http://www.a-lok.com/pdfs/Key-Lok.pdf
Did not know what I was looking at in the picture. Looked like a floor drain and weep holes, like a roof drain.
Marcel
Old 3/31/08, 7:34 PM
Banned
Yeah, but is this thing floor drain sized (4-6") or manhole sized (3')? The picture lacks perspective.
Old 3/31/08, 7:39 PM
I know Mark, if it is 4-6", so they must be weep holes. ha. ha.
I would be curious to know what that piece is in the side that looks broken.
Marcel
Old 3/31/08, 8:05 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
My guess is that is at least 20" diameter. (Needs cleaned by the way) How many bays in the garage? That odd looking stand pipe resembles and Agitator, not sure how it works, takes water to the bottom to stir. Holes indeed are place correctly for lifting.
But it wouldn't be the first time I was wrong.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 3/31/08, 8:19 PM
Think I got a few more.(pics) not holes.
there were two others with a bigger one near by.
2 town houses were across from each other with garages each facing each other. main driveway between
Old 3/31/08, 8:23 PM
Dale Duffy's Avatar
Hey Bob.....
They could be weep holes for surface water around the bottom exterior of the manhole top.....
If so, don't mortar them......
Old 3/31/08, 8:27 PM
That was my first thought when I saw them.
Like the crane lift idea better though.
I stuck the driveway reflector stick in and got only a few inches before hitting something.
Now I know how other guys feel.
Old 4/1/08, 8:36 AM
Rick K. Kie's Avatar
Rick K. Kie Rick K. Kie is offline
If the fitting is treaded at the other end they could just be holes for a device for screwing it in. Or vent holes. I think probing the hole whould help to determine its purpose. There is my two cents
Rick Kie
Old 4/1/08, 12:11 PM
mnahrgang's Avatar
My question is (and no offense meant): What in God's green Earth ever possessed you to open an exterior drain? Is that something that is required by IL licensing?
Mark Nahrgang
www.HeyMark.info
Brick house nbhi Exterior Inspections 28 2/17/08 3:22 PM
Question about weep holes. gromicko Exterior Inspections 10 1/28/08 10:25 AM
Brick-Veneer Inspection Guide jbowman Exterior Inspections 12 1/8/07 9:20 AM
Sink Holes May 13th zfackler General Inspection Discussion 0 5/2/06 11:01 AM
Weep Holes dgarbade Miscellaneous Discussion for Inspectors 1 3/7/06 11:28 PM
