Is there any problem here? First time in 3 years to run into this plumbing under a kitchen sink. The PVC goes into the main drain which is galvanized
After the trap, when the pipe tuns down to an additional horz run - all require an increase in the pipe diameter (Vertical Leg Waste Fixture Drain).
Where the two sinks/drains meet at the "T" - there should be a directional fitting, not a tee. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks Jeff
| Fetch Report problem | mhazelwood | Misc. Discussion | 7 | 11/12/07 12:12 PM |
| Is MAC a problem | bemelander | General Inspection Discussion | 2 | 9/6/07 12:34 PM |
| Camera Problem | nwagner | Misc. Discussion | 19 | 7/30/07 11:10 PM |
| Plumbing problem at home. | mnahrgang | Plumbing | 25 | 7/10/07 6:32 PM |
| Very tough problem | Albert Detorre | HVAC | 7 | 2/23/07 1:01 PM |
