Why don't people measure twice and install once so we don't get these goofy looking things? Anybody forsee any future problems with this trap?
Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County Last edited by sstanczyk; 3/22/09 at 2:31 AM.. |
i don't realy see an issue. it looks funny because of the twist in the slip nut. but if you straitened it out, it'd look normal. so long as there is a vent in the system i see no issue.
I can't tell for sure, but it looks like they used a san-T incorrectly (horiz to horiz). The p-trap should should feed into a long radius 90 or a combo fitting.
should, but not "has to" there is no correction needed in this case....unless of course the vent is horizontal as you said Paul. but it's realy dark in the pic and impossible to be sure.
Ask yourself this question is it performing it's intended function. If it is there is no problem there.
My two cents.... |
I agree if you fill both sinks up and then let the water out the sink on the right will drain first then the other with good pressure . It would have been nicer if the main drain with the claenout had a little more pitch to it , but still it should function OK
Tim Spargo is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like a Vent fitting Sani-T for Vertical use. Comby is correct fitting there. At least that what what it looks like. Comby radius was probably too long to make trap connection to sink etc.. work.
| Fetch Report problem | mhazelwood | Miscellaneous Discussion for Inspectors | 7 | 11/12/07 12:12 PM |
| Plumbing problem at home. | mnahrgang | Plumbing Inspections | 25 | 7/10/07 6:32 PM |
| Negative angle trap arm issue | rlind | Plumbing Inspections | 4 | 4/15/06 12:00 AM |
| Grease Trap / Drum Trap | David White | Plumbing Inspections | 1 | 2/7/06 6:41 PM |
