What would you report on this one? I am looking for that classic NACHI input! I just had to post this!
I would have to post " call a plumber now" LOL
Wow! Definitely not installed according to manufactures instructions.
incredibly expensive but inappropriate use of drain fittings...
Only thing I can think of is "What were THEY thinking".
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
The accordian style waste line has been installed in an un-workman like manner and is succeptible to to "clogging" Recommend having the necessary repairs made by a licensed plumber.
Hope that helps. Those accordian waste lines are more likely to clog, even if they are installed properly. Priority Home Inspections has teamed up with the Dish Network to give you a FREE Dish Network system. Log onto www.Free-Dish-For-You.com for all the details. Priority Home Inspections, Inc. 321-368-9921 www.BrevardHomeInspector.com www.AvoidAMoneyPit.com www.BrevardInsuranceSavings.com www.BrevardBuildersWarranty.com www.PrioritySignPosts.com Info@BrevardHomeInspector.com |
You don't need a long drawn out explanation of this comical waste pipe installation...
"Improper waste pipe installation, have a licensed Plumber evaluate and estimate repairs to kitchen waste piping". |
Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
If that mess isn't leaking, with all the submerged slip joints, it would be amazing. The hardest thing to fix there is the height of the drain outlet. It looks like the garbage disposal may never drain completely.
fubar. . .
"The kitchen sink and disposer is not plumbed correctly and is likely to cause problems with drainage in the future. Have a licensed plumber install the drainage system consistent with current plumbing standards" Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
I would run an ad in the Lost & Found, "Missing Robot from Lost in Space found".
I like comments short, sweet, and to the point--
</IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Makes you wonder if they do things like that intentionally, you would think the odds of them accidentally doing one correctly would be 50-50--- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Don't you think. 1:100 would be closer. ha. ha. Marcel LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
| Thoughts on this panel | Danny Castellano | Electrical Inspections | 9 | 8/22/06 7:09 PM |
