Found this in a hall closet and when i went to the crawl space it just seems to be part of the water line. What are you thoughts
| Find an InterNACHI certified Arizona Home Inspector (and anywhere else in North America) |
It's most likely a loop for a future water softener system.
Excellence in Inspections Mike Boyett, TREC #7290 mikeb@capcityinspections.com Capital City Inspections Austin, Texas (512) 577-2579 Company blog is: www.capcityinspections.com/blog |
Mike, apparently, has access to my thoughts, too.
Probably future hydroponic irrigation piping.
Or There is CPVC water piping in the closet that we recommend that you ask the current owners about. |
It doesn't look like CPVC to me, if it is, they used the wrong "glue."
PVC is not allowed for interior use as supply piping - regardless of its application. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Supply or waste? Simply recommend that a Plumber remove this nuisance piping. |
Could it be a (or an additional) water service shut off so a person would not have to access the crawl space to shut off the water? PVC is used aound here often for service lines.
Sincerely, Richard Wiley Ocoee River Home Inspections PO Box 988 Copperhill, TN 37317 706-455-2644 rwiley@ocoeeriverhomeinspections.com www.OcoeeRiverHomeInspections.com |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I'll bet you a dollar it's PVC. It's way too white for CPVC, but I would have still looked for the markings.
Check your local codes. Most model codes don't allow for PVC pipes for distribution within the residence, but most allow service piping to be PVC. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Kinda what I was thinking too especially if it's a weekend or vactaion home.
dgagneur is a non-member guest and is in no way affiliated with InterNACHI or its members.
| Thoughts on this panel | Danny Castellano | Electrical Inspections | 8 | 8/22/06 8:09 PM |
