Old 2/8/09, 9:54 PM
Peter W. Bennett Peter W. Bennett is offline
Default AO Smith W/H 5-90deg elbows
The trpv of AO Smith water heater has 5-90deg elbows.
I could not find a manual that mentions number of bends nor types (i.e., 45/90 etc.)
Is there a limit?
Anyone have an AO Smith manual for a natural water heater?
Model FSG 50 248
SERIAL NO. MK02-1996942-248
Thanks,
Peter
Old 2/8/09, 10:19 PM
Jeff Moore Jeff Moore is offline
Please Note: Jeff Moore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: AO Smith W/H 5-90deg elbows
I am trying to visualize this arrangement.
Any pictures?
Old 2/9/09, 3:10 AM
Russel Ray's Avatar
I don't have an AOS manual, but the most I've seen allowed in a manual is six, and all the manuals that I have read have said to keep the TPR drain pipe as short as possible while terminating it 6-12 inches above the ground.
Old 2/9/09, 10:42 PM
jkogel jkogel is offline
Here's the link to the AO Smith website: http://www.hotwater.com/lit/im.html
No manual for your model, but this one is similar, assuming you mean natural gas.
http://www.hotwater.com/lit/im/res_gas/184123-000.pdf
On page 10 of this manual, halfway down the left column........
"Excessive length, over 30 feet, or use of more than four elbows can cause restriction and reduce the discharge capacity of the valve."
Please allow ample time for moderation of this post. Hope it helps.
John Kogel
www.allsafehome.ca
Old 2/9/09, 11:55 PM
Brian E. Kelly's Avatar
AO Smith recall gheller Plumbing Inspections 0 8/24/08 8:30 PM
CPSC Recall- A.O Smith Water Pump Motors pabernathy Electrical Inspections 0 6/24/08 8:13 PM
CPSC Recall- A.O Smith Recalls Water Pumps pabernathy Plumbing Inspections 0 6/24/08 8:11 PM
A.O. Smith water heater recall Gary Reecher Inspecting HVAC Systems 0 4/4/08 12:18 AM
AO Smith Recall ldapkus Plumbing Inspections 2 4/3/08 8:01 PM
