Old 4/18/06, 10:15 PM
Joe Funderburk, CMI's Avatar
Default Appliance connector in crawl space
Found this today under a modular home. The manufacturer's instructions don't specifically say "hey dummy, do not install in crawl spaces." But it is supposed to be viewable for periodic inspection. And it is supposed to have a shutoff valve directly in front of it.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 4/18/06, 10:50 PM
Jeffrey R. Pope's Avatar
Default Re: Appliance connector in crawl space
Not allowed unless it's connected to an appliance (hence, the name). It would also require a shutoff valve at its supply side.
But you already knew that
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/18/06, 11:25 PM
I knew it could not pass through walls. I also knew this didn't look right. Stopped by Lowes and read the manufacturer's instructions. If anyone is interested, the instructions are also here:
http://dormont.com/dmc/uploadedFiles...structions.pdf
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/14/06, 6:05 PM
Can these appliance connectors be used at gas furnaces in crawl spaces, assuming a gas shutoff is directly in front of it? The manufacture says the connector is "not to be concealed". Seems like a crawl space would meet the definition of being concealed.
In the attached photo, there is no gas shutoff, but otherwise is it OK to be in a crawl space?
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/14/06, 6:33 PM
Roy D. Cooke, Sr's Avatar
good info thanks Joe . Roy cooke sr
Old 6/14/06, 6:45 PM
A crawl space is no more concealed than an attic. We see them there all of the time. They are generally considered "accessible" in crawls and attics.
Concealment is generally referring to areas where there is no access, such as within wall cavities and such.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 6/14/06, 9:28 PM
Bruce A. King's Avatar
Those can not pass through equipment cabinets either.
I called the manuf. about that before and they agreed.
Code check has it under 2422.1.2
Old 6/14/06, 10:24 PM
Joseph Hagarty,  CMI's Avatar
Thanks for the Link.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 6/15/06, 12:05 AM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
Where I plumbed this would be illegal. It would have to be either black iron or an improved flexible gas line such as Gastite. It had to have easy access and a crawl space or attic was not considered easy access.
Old 6/15/06, 10:27 PM
Guess I better call the AHJ. I'll let you know what I find out.
Theodore Roosevelt
Joe Funderburk, CMI
Old 6/16/06, 4:59 PM
hbeard hbeard is offline
according to these instructions the gas connector should be in the same room as the appliance.....so would this being in the crawlspace be illegal?
Old 6/16/06, 5:12 PM
Harold, the original post, the first picture, is definitely incorrect. My 2nd question about using them in a crawl space when the appliance is also in the crawl space meets the rule you reference. I have yet to call the AHJ because there are some conflicting opinions amoung our local experts.
Theodore Roosevelt
Joe Funderburk, CMI
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 7:43 PM
Crawl space in under house dnasser Structural Inspections 15 2/27/07 7:12 PM
Space At Units sparks Inspecting HVAC Systems 5 1/8/07 1:57 PM
Another reason to recommend CO testers rnewman1 Interior Inspections 2 10/12/06 7:47 AM
