http://www.cpsc.gov/cpscpub/prerel/prhtml08/08205.html
LDR Industries Recalls Gas Connectors Due to Fire and Explosion Hazards WASHINGTON, D.C. - The U.S. Consumer Product Safety Commission, in cooperation with the firm named below, today announced a voluntary recall of the following consumer product. Consumers should stop using recalled products immediately unless otherwise instructed. Name of Product: LDR 1200 Series Gas Connectors Units: About 50,000 Importer: LDR Industries Inc., of Chicago, Ill. Manufacturer: Sai lin Ke, of Beijing, China Hazard: The gas connectors can leak propane or natural gas, posing a fire and explosion hazard to consumers. Incidents/Injuries: None reported. Description: The recalled LDR series 1200 gas connectors have 3/8 inch fine thread nuts attached. The connectors are used primarily with gas space heaters. The brass nuts are gold colored while the stainless steel tube is silver colored. The following connectors are included in this recall. The UPC code and “LDR 1200 Series Gas Connector” are printed on the product’s packaging. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ℠ Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Thanks for the info, Jeff
"You cannot depend on your eyes when your imagination is out of focus"...Mark Twain Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota NACHI07013103 IAC2-01-1567 |
| Gas and oil hot water tank and Boiler Share Vents | hvanderbeek | Misc. Discussion | 8 | 1/25/07 6:22 PM |
| Space At Units | sparks | HVAC | 5 | 1/8/07 2:57 PM |
| Another reason to recommend CO testers | rnewman1 | Interior | 2 | 10/12/06 8:47 AM |
