“The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 1/29/10 at 11:41 PM.. |
| Need a home inspection in Florida? Check out InterNACHI's listing of Florida certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Drew Levy NJ# 24GI00101400 Radon # MET12929 Homespect LLC (609) 668-7588 http://www.homespectllc.com http://www.philadelphiahomeinspection.net http://www.southjerseycommercialinspection.com http://www.haddonfieldhomeinspection.com http://www.abseconhomeinspection.com http://www.willingborohomeinspector.com http://www.thehomeinspectioninstitute.com |
Is the gas line laying across the cooper pipe?
Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
Flex connectors for gas fireplaces are usually allowed to pass through floors or walls. I had a similar situation last year and found the code for it somewhere, but can't find it now. I'll look again in the morning.
http://www.SmithHomeInspection.com SmithHomeInspection@yahoo.com NY State Lic. # 16000008304 631-434-5200 |
I have never heard of that. Walls yes floors no. I would be interested in knowing.
This is from instructions for the common Dormont piping:
4. DO NOT install the gas connector so that it is concealed within or runs through any wall,floor or other partition. The gas outlet must be in the same room as the appliance. This is so it is visible for periodic inspection. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
How long is the connector? Where is the shut off?
It was probably 6 feet long. The shutoff was beneath the firebox of the manufactured fireplace.
Here's what I said: "A gas appliance connector passes through a floor; a practice which the manufacturer prohibits. The manufacturers of these devices state: "Do not conceal connector or run connector through enclosed outdoor BBQ pits, walls, partitions, floors or appliance panels." Service by a licensed plumbing or HVAC contractor is recommended." That quote came from a connector I picked up at Lowes a long time ago and documented the warning. “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
M2202.3 of the IRC 2006 allows it when rigid connections are impractical and to reduce jarring and vibration. labeled in accordance with UL 539.
From the picture I don't see anything impractical as to why a rigid line coudn't be installed the only other thing not seen is the absence of a dripleg. Another question is were the line passes through the wall, should it be sleeved or insulated |
"M2202.3 Flexible connectors. Flexible metal hose used where rigid connections are impractical or to reduce the effect of jarring and vibration shall be listed and labeled in accordance with UL 536 and shall be installed in compliance with its label and the manufacturer’s installation instructions. Connectors made from combustible materials shall not be used inside of buildings or above ground outside of buildings." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com Last edited by jfunderburk; 1/29/10 at 11:59 PM.. |
Looks like it. I didn't catch that. Aren't those connectors stainless? Would that present a corrosion problem???
Technically it would but the amount depends on the environment. You already said it was an improper installation so it is a moot point as far as the report goes.
I'll be shocked if you find a code that says it's OK to violate the manufacturers' installation instructions, which prohibit that practice.
I wasn't refurring to the hvac cabinet, by the time I got my first post off you asked another question. I need to type faster
| Max load allowed on 2x2 ledger | bking | Structural Inspections | 4 | 12/23/07 2:05 PM |
| Where do I put the Aquarium? | mcyr | Structural Inspections | 3 | 11/6/07 3:05 PM |
| Another reason to recommend CO testers | rnewman1 | Interior Inspections | 2 | 10/12/06 7:47 AM |
