Old 4/8/06, 7:51 PM
jweinberg's Avatar
jweinberg jweinberg is offline
Please Note: jweinberg is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Appropriate fuel connection?
Is this appliance fuel connector considered appropriate and flexible enough for use in a seismic region?
I've always seen the flexible (corrogated metal tubing) fuel connectors on water heaters.
Old 4/8/06, 11:16 PM
Jeffrey R. Pope's Avatar
Default Re: Appropriate fuel connection?
Not allowed by the CBC. You are also lacking seismic straps, but you probably knew that.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Grounding rod connection from meter box fbartlo Electrical Inspections 37 7/28/07 12:30 PM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 2:28 PM
Another reason to recommend CO testers rnewman1 Interior Inspections 2 10/12/06 7:47 AM
Fuel Master W/H date bsmith Plumbing Inspections 2 6/2/06 10:59 PM
