Old 11/22/09, 2:12 PM
David C. Macy's Avatar
David C. Macy David C. Macy is online now
Default Approved gas pipe?
The meter was on adjacent exterior. The main fuel pipe is located in garage.
Is this an acceptable material?
Any report verbiage would be appreciated.
I was looking through the National Fuel code and this does not appear to be properly sleeved and I am unsure of the material.
Find an InterNACHI certified North Carolina Home Inspector (and anywhere else in North America)
Old 11/22/09, 2:35 PM
Default Re: Approved gas pipe?
It looks like CSST with the covering removed.
Larry Kage, CMI
231 929 3525
Old 11/22/09, 2:41 PM
I believe when it is run through exterior walls it needs to be sleeved, also.
Larry Kage, CMI
231 929 3525
Old 11/22/09, 5:16 PM
Brian E. Kelly's Avatar
I would be inclined to believe this also.
Old 11/22/09, 7:44 PM
So, you're a believer...
Larry Kage, CMI
231 929 3525
Old 11/22/09, 8:04 PM
Larry, that is surprising to see Brian as a believer.
Not sure about residential, but Commercial, nothing but hard pipe is approved to go through an exterior wall, permanent or temporary installations both.
Maybe it is a State Regy or something.
Old 11/22/09, 8:36 PM
Having seen/inspected miles and miles of every kind of pipe carrying all types of Gasses/Liquids/Cryogenic Fluids, yes I believe in proper piping installations.
Old 11/22/09, 11:04 PM
David A. Andersen's Avatar
I go along with this as well.
No flex or connections in the wall. CSST allowed in INTERIOR locations IAW Mfg recommendations.
Gas connectors will not pass through building or appliance wall.
BPI# 5015804
Old 11/23/09, 9:11 AM
Just razzin' ya, BK...
Larry Kage, CMI
231 929 3525
Old 11/23/09, 2:58 PM
I know, and I like it. As for flex pipe in walls, that is allowed by the manufacturer and the code. Local codes may not allow it.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Is this allowed? belliott Plumbing Inspections 4 7/15/09 6:40 PM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
