Old 3/14/06, 6:27 PM
Brian E. Kelly's Avatar
Default Artist or Incompetent, You make the call.
2 year old gas water heater.
So I look at the piping in the first picture and am standing back admiring the tube bending job. Ah beautiful, done by a craftsman, I am saying to myself. I am so enamored with the work I almost overlook the tank nipples and the next photo. Now I am confused, how can someone take such care with the tpr piping and then not use a dielectric fitting?
Old 3/14/06, 7:50 PM
Jeffrey R. Pope's Avatar
Default Re: Artist or Incompetent, You make the call.
Are you kidding? That bend was done with an electricians' conduit hickey
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/14/06, 7:52 PM
Conduit Hickey?
The technical jargon is not my strong suit, Jeff.
Old 3/14/06, 7:54 PM
Ted Allen Ted Allen is offline
If they used a "hickey" they have had a lot of practice.
Old 3/14/06, 7:57 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Is it a "doo-hickey" for bending pipe?
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 3/14/06, 8:04 PM
Maybe if they used a rebar hickey, but it's pretty easy with a conduit hickey.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/14/06, 8:07 PM
I have bent a lot of conduit with a "hickey" and it's not easy to keep the little dents out of regular electrical conduit, it seems it would be very hard to do with something as soft as copper.
Old 3/14/06, 8:09 PM
I think it was heated and then bent around the WH to get the "perfect" fit.
Old 3/14/06, 8:12 PM
Well maybe a sparky did the install, that would explain the lack of dielectric.
But they shoud have used the proper tools.
Old 3/14/06, 8:35 PM
phinsperger's Avatar
Or you fill the pipe with sand, plug the ends, and use the hot water tank itself to bend the tube around (as close to the top or bottom of the tank as possible so as not to dent the tank). Unplug the ends and dump out the sand. viola!
Or
you could just cut a peice out of copper tubing (not pipe) as it is still coiled up. The coils are fairly close to that diameter anyways.
Old 3/14/06, 8:36 PM
Brilliant!!!
Old 3/15/06, 1:47 AM
jclark1's Avatar
jclark1 jclark1 is offline
Please Note: jclark1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Actually Jeff, the tool you showed is a emt bender. A hickey is used for small rigid conduit.
Old 3/15/06, 4:17 AM
Russel Ray's Avatar
viola!
Viola?
I play the violin and the piano, and I sing. Jim also plays the piano. Hop on over this way and we could have a chamber music trio.
Old 3/15/06, 8:44 AM
Mark A. Timpani, CMI's Avatar
Mark A. Timpani, CMI Mark A. Timpani, CMI is offline
very nice
"Be Proud of Your Home, Go With Pride!"
'Not just a Home Inspection, but an Education'
Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties.
Old 3/15/06, 8:50 AM
bkelly1's Avatar
bkelly1 bkelly1 is offline
Please Note: bkelly1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bingo! The other bender showed is a typical EMT (thinwall) Bender.
Last Call for INSPECTVUE SOFTWARE DISCOUNT $845.00 includes Tax...... jwatts1 Inspection Hardware, Software & Publications 4 8/8/07 10:47 AM
You Make the Call bkelly2 Structural Inspections 13 4/13/06 12:17 AM
