Old 4/1/07, 4:45 PM
afrost afrost is offline
Please Note: afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default ask the experts - i'm looking for advice
my water supply (drilled well) is 1" copper that feeds a pex manifold with 1/2" distribution lines. i want to install a whole house waterfilter. the one i picked up has 3/4" inlet and outlet. it would be installed before the manifolds. will the 1" to 3/4" reduction and the introduction of a water filter affect my water pressure?
advanced thanks!
andy frost
Old 4/1/07, 5:03 PM
Jeffrey R. Pope's Avatar
Default Re: ask the experts - i'm looking for advice
Pressure will remain the same, but your flow rate will be reduced. The impact will depend on how many fixtures normally operate at the same time.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 4/1/07, 8:20 PM
homebild homebild is offline
Water Filters, water softeners, backflow preventers, temperature balancing valves and similar devices all reduce water pressure regardless of pipe diameter and must be accounted for when sizing pipes for the entire distribution system.
Depending upon where the water filter is located relevent to the highest fixtures and developed length of the pipe, there can be a susbstantial overall pressure reducing effect from the installation of a whole house filter.
The manufacturer of the appliance should have the expected pressure reduction rating listed within the technical data sheet for the product.
Old 4/1/07, 8:50 PM
Pressure (PSI) is not affected by filters and such (except for pressure regulators). Flow rate (GPM) is reduced by all of these things you mentioned.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 4/1/07, 8:51 PM
hmmm, two teenage daughters -- all the fixtures all the time!
seriously, we could have two showers, washing machine & a toilet going in unison.
i'm trying to sift out any grit before the water enters distribution. i've got no other water issues, just trying some prevention. i guess i'd put a filter at the kitchen if i test for some potability issues.
any suggestions for whole house?
thanks
Old 4/2/07, 6:45 PM
jkormos's Avatar
jkormos jkormos is offline
advanced thanks!
andy frost
Andrew, GE has a 1" fitting on a whole house filter, you can pick one up at Home Depot. about $50.00 You may also want to upsize your preasure tank as well if you are looking for capacity
Joe Kormos
A-1st Look Home Inspectors Inc.
630-201-0933
Your 1st Choice in Property Inspection Professionals
www.a-1stlookhomeinspectors.com
www.a-1stlook.com
Let us look before you buy...for peace of mind
“Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford
Home depot experts rparker Canadian Inspectors 24 7/21/07 7:48 AM
supposed waterproofing experts who were looking to partner with Nachi john bubber Structural Inspections 6 6/15/07 7:34 PM
For all the experts here! cbrown1 Ancillary Inspection Services & Additional Topics 15 2/15/07 3:04 PM
Electrical Experts Needed!! jbowman Electrical Inspections 12 3/29/06 11:52 AM
