I have never seen water supply lines routed through an attic. Looking for opinions from any inspector who has encountered attic plumbing. Keep in mind the cold environment for the Maryland area where this home is located. Yes, there is a heating element for the cold water side and as you can see foam insulation. Of course, the heating element could fail.
Attic-routed plumbing is very common. . .
Even in cold weather climates?
No, that Pope fella forgets he lives in California.
That metal braided heat cable has me wondering if that is a legitimate install for that product. Any tags indicating who the manufacture is? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
True dat.
How do you repipe in colder climates (assuming no basement and no crawl space)? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Michael,
Did not notice a tag, the thermostat is Honeywell. I think the plumbing may have been re-routed from the original slab location. You can see the slab with abandoned copper & poly lines in the photos posted in the Structural Section yesterday. It all seems to be tied together. |
The insulation traps the heat from below and warms the pipe. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Why no pipe insulation?
It is not needed and you want the pipe exposed to the warmest temp just above the interior ceiling materials.
Even if you have to run the pipe perpendicular to the joists or truss bottom chord, all you have to do is have the insulation go up and over the pipe with no insulation below it. Of course this is problematic with any blown in insulation systems and would require a open sided half box above the pipe. You need to trap the warm from below for it to work. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
Thanks for the information. I spoke with a local retired inspector who was in the business for 21 years, and he does not recall ever seeing water supplies in an attic. But, there may have been occasions when the plumbing was concealed below the insulation as you suggested.
A prudent man might point out that there is no freeze alarm or any other warning device that would warn of heat tape failure. Heat tapes do have a lifespan, but it's unclear to me what that might be. I replace them from time to time, typically under mobile homes, but normally only following a pipe failure. There are commercially available freeze alarms with a probe you stick under the Armaflex. An extended power failure would also put the pipework at risk for freezing if the home was not equipped with a generator or provisions to connect a portable generator. This might be something worthwhile to point out.
Update. According to the local plumbing inspector, this installation is not allowed. As mentioned in this thread, the county may possibly allow attic plumbing if placed above the ceiling and covered with adequate insulation.
Pretty common to have water heaters in attics here. This is what I say, depending on whether or not insulation is provided.
"The visible portions of the water pipes in the attic are insulated and are in acceptable condition, but should be monitored because of their location. Leaks from pipes that pass through an attic can be soaked up by insulation, and are difficult to detect until significant damage is evident elsewhere." "Water pipes in the attic are un-insulated and insulation is recommended to prevent freezing. The pipes should be monitored because of their location. Leaks from pipes that pass through an attic can be soaked up by insulation, and are difficult to detect until significant damage is evident elsewhere. Note: combustible insulation should not be closer than 1" to a water heater flue." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Did you note that where the pipes are fastened to the rafter legs that the insulation has been cut and removed? This may allow the cold climate to transfer to the pipes, and also may make the heat tape work more. The insulation should have been left on in these areas and large straps around insulation & pipes. I generally use conduit clamps sized to fit the O.D. if the insulation myself. Also the I.D. of the insulation should be sized to fit the pipe plus the heat tape. It looks as if some of the insulation seams were slightly open. They need to be closed tight.
Looks like Frost-Tek type heat tape. This is about the best I have found to use. Scott A. Figert www.sfigert.com www.nachi.org NACHI #06042595 Figert Building Inspection, Ltd. (419) 399-4472 Office & Home Sweet Home |
There are open insulation joints from apparent shrinkage or movement. The joints were taped together at one time, the tape residue is visible.
Mounting the copper so high above the ceiling does not appear to be correct, and is not according to our local county inspector.
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 2:28 PM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
| A few useful posts - I forget from whom | jmichalski | Plumbing Inspections | 12 | 3/30/06 9:06 PM |
