When I was testing the 2nd floor master bath plumbing I was running the water at both sinks. They drained fine.(Or it seemed so at the time) I left the water on at the sink to test the flow.
When I went to test the tub plumbing the water from the sinks was backing up into the tub. The home has been vacant for awhile. As you see in the pic it appears there is some sand/grit debris. Do you think the problem is with the tub plumbing or would you advise the hole DWV system be scanned. It seemed just to be the master bath that was an issue, Toilets flushed OK. First floor Half bath OK. |
Let a plumber figure it out. Your job is complete.
"The tub drain is blocked and should be serviced by a licensed plumbing contractor to ensure that the blockage does not involve the main sewer line." “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Well said Joe
David , if it had a drum trap, that is your culprit.
![]() This is oversimplified, but as you can see if the tub is stopped and the lavs are filling the tub then the stoppage is below where it drains into the stack. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
By the way, I agree your job is done when you find the stoppage.
| Clogged Drain? | aberdahl | Plumbing Inspections | 2 | 6/28/08 11:04 PM |
| Inspector in hot water after approving unit without drain | rcooke | Canadian Inspectors | 7 | 2/20/08 3:59 PM |
| Back to court again and I luv it. | cbottger | General Inspection Discussion | 4 | 6/28/07 8:38 AM |
| Washer Secondary Drain | roconnor | Plumbing Inspections | 7 | 4/2/06 1:02 PM |
