Old 3/24/07, 10:23 PM
Larry E. Freeze Larry E. Freeze is offline
Default Backflow prevention for dishwashers
I imagine, optimally, an air-admittance valve would be in order.
But what about dishwashers w/o AAV's?
Is an upward slope from the dishwasher and then a slope downward
toward the garbage disposal (or waste drain) acceptable?
I have seen some that have virtually completely level d/w drain slope,
and previous owners have complained about dirty water being left in the bottom of the dishwasher after a cycle.
I certainly write those up.
But back to ?: Is upward slope from d/w and then downward slope toward waste drain good enough for anti-backflow?
Old 3/24/07, 10:25 PM
Default Re: Backflow prevention for dishwashers
Typically, yes. It's called a high loop.
Larry Kage, CMI
231 929 3525
Old 3/24/07, 10:28 PM
Thanks!
That's what I figured.
Now I know what it's called !
Thanks again,
Larry
Old 3/24/07, 10:54 PM
Jeffrey R. Pope's Avatar
I assume you're actually referring to an air-gap rather than an AAV.
AAV's are a vent system which has nothing to do with back-flow prevention. An air-gap device is used in dishwasher drain lines to prevent back-flow.
High-loops are allowed by many model codes, but not here in CA.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/25/07, 12:10 AM
Russel Ray's Avatar
As with everything, though, final say-so is up to the local AHJ. I have a gazillion bazillion brand new multi-million dollar homes in brand new subdivisions with dishwashers on kitchen islands where the local AHJ here allows high loops.
Old 3/25/07, 11:39 AM
I see these often too. But the code is very clear about this, and it should be mentioned in your report.
Here's how I state it. . .
The dishwasher is functional but discharges without an air-gap fitting, which is mandated by California Building Standards. The absence of the air-gap fitting may also create a drainage problem and a health hazard.
and here's the code. . .
CPC 807.4 No domestic dishwashing machine shall be directly connected to a drainage system or food waste disposer without the use of an approved dishwasher airgap fitting on the discharge side of the dishwashing machine.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/25/07, 12:00 PM
Russel Ray's Avatar
I mention it, but I don't use code references or "mandates" like you do.
And it's still up to the local AHJ to interpret:
Old 3/25/07, 1:19 PM
Not much left to the imagination here, it's pretty cut and dry.
No dishwashing machine shall be connected to a drainage system without an airgap fitting.
Now, obviously, a variance can be obtained to circumvent almost any code requirement, but I am certainly not going to just "assume" this has been done. The homeowner can do the work to verify this.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/25/07, 1:25 PM
Russel Ray's Avatar
Sometimes the AHJ does probably use his imagination for purposes of interpretation.
Or they can hire me as a consultant to verify it at $100 per hour, which several have done. Now that I know what subdivisions are involved, I can simply put the information in my report, and if they still want me to verify current interpretations, I do that.
Old 3/25/07, 8:07 PM
cjudkins cjudkins is offline
If it does not have an AAV , The discharge hose must be atleast 32 inches long and extend above the level of the dishwasher per the IRC
Old 3/25/07, 9:22 PM
An AAV is a vent system. An AAV is not the same as an air-gap or high-loop, and it performs a completely different function.
Jeff Pope
Santa Clarita CA
(661) 212-0738
asking help regarding backflow preventer afrost Plumbing Inspections 7 5/2/07 8:08 PM
Backflow Preventor AND Pressure Reducing Valve??? tlorenz Inspecting HVAC Systems 1 9/26/06 8:08 AM
Backflow inspection dbucknavich General Inspection Discussion 6 8/10/06 1:46 PM
An Ounce of Prevention, How Not to get Sued by Mark Cohen gromicko Miscellaneous Discussion for Inspectors 0 2/6/06 2:10 AM
