Old 4/23/09, 8:12 PM
James B. Gibbs James B. Gibbs is offline
Default What is a Balance Reducing Valve
Inspecting a new home yesterday I saw a copper line from the cold water supply to a drain line. The water was on and there was no discharge from the drain pipe. The builder responded with this explanation. "
That is a BRV (Balance Reducing Valve). You have a PRV (pressure reducing valve) that is tied into the main water line in the flower bed. If that was to fail, the BRV valve will keep the water heater in check and keep it from leaking."
Can anyone enlighten me on this?
Thanks
Jim
Jim Gibbs
Gibbs Residential Inspections
TREC Professional Inspector License 6854
Texas Mold Assessment Technician License MAT0218
972-822-7898
Find an InterNACHI certified Montana Home Inspector (and anywhere else in North America)
Old 4/23/09, 8:25 PM
Michael Larson's Avatar
Default Re: What is a Balance Reducing Valve
Series: BRV
Description: Combination Ball Valve and Relief Valves
Size Range: 3/4 to 1 in. (20 to 25mm)
Series BRV Combination Ball Valve and Relief Valves are used in commercial and residential applications on water heater installations. It consists of a bronze body construction with a full port (reduced port with PEX connection), nickel-plated brass ball, blowout-proof brass stem, PTFE seats, stem packing, and stem thrust bearing, Viton relief ball, stainless steel relief spring, brass adapter, and steel handle (the relief valve outlet includes a drain tube connection with PEX or compression fitting models). Series BRV has a low profile design and can be installed in any position. It is for applications that require a means to shut off the water supply to the water heater and for providing protection from excess water pressure caused by thermal expansion. Pressure Rated: 400psi. Relief Valve Pressure Settings: 75, 80, 100 or 125psi (5.2, 5.5, 6.9 or 8.6 bar).
Michael Larson
Hudson, WI
[/I]
Old 4/23/09, 8:32 PM
Thank you.
Does this take the place of an expansion tank?
Jim
Jim Gibbs
972-822-7898
Old 4/23/09, 8:36 PM
Originally Posted by jgibbs View Post
Thank you.
Jim
Yes, if permitted in your jurisdiction.
Michael Larson
Hudson, WI
[/I]
Old 4/23/09, 8:40 PM
I appreciate the help.
Jim
Jim Gibbs
972-822-7898
Shut off valves required? jcahill Plumbing Inspections 11 9/2/08 1:07 AM
Backflow Preventor AND Pressure Reducing Valve??? tlorenz Inspecting HVAC Systems 1 9/26/06 8:08 AM
