Old 1/25/07, 5:31 PM
Ian Gills Ian Gills is offline
Please Note: Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Ball valves
I am having a professional plumber replace my aging gate valves on my main water supply line (one below the meter, and one after) with ball valves. I like ball valves. Are there any problems with using them as mains shut-off valves, before it is too late?
Old 1/25/07, 5:38 PM
Default Re: Ball valves
Preferred by discriminating plumbers everywhere...
Actually, they are the valve most used these days.
Old 1/25/07, 5:40 PM
Thanks Jae. I wish I could meet a discriminating plumber here in the US. Don't get me wrong, they do a good job, but most just do the job you want done not the one that might be better at a slightly higher (equipment) cost.
If I did not ask for ball valves, they would be replaced with gates.
They will replace the toilet, but not the shut-off valve unless we ask. No wonder so many of us try DIY.
Old 1/25/07, 5:48 PM
wsiegel wsiegel is offline
I would probably be a good idea to replace the shut off to the toilet also. If it is old, it will probably leak.
Old 1/26/07, 5:43 PM
twasion twasion is offline
Please Note: twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've used them for over a decade with no problems. I used them on my house. Use them and sleep well at night.
Does anyone know anything about corrugated stainless steel tubing (CSST)? gromicko Structural Inspections 5 9/28/07 6:24 PM
Air admittance valves everywhere apfaff Plumbing Inspections 13 4/16/07 9:17 AM
