Old 1/26/13, 7:03 AM
David C. Macy's Avatar
Default Basement floor drain
Home built in 2002.
Flooding had occurred and they installed this sewer drain in the floor.
Besides the cracked tiles, water above the inside cover do you have any thoughts about this?
I set up a radon before hand and my client was concerned about the past flooding and this particular drain.
Thanks!!
ID:	61847   basement-floor-drain-img_0005-small-.jpg.JPG
Performing Home Inspections in Cleveland, Strongsville, Brecksville, Broadview Heights, North Royalton, Parma and surrounding areas.
http://www.hshinspections.net/
Need a home inspection in Colorado? Check out InterNACHI's listing of Colorado certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/26/13, 7:19 AM
Larry Kage, CMI Larry Kage, CMI is offline
Default Re: Basement floor drain
It looks like a homeowner mess that may just drain into the ground below that location. I'd refer it out. Scoping may tell part of the story.
Larry Kage, CMI
whis11 @ charter.net
The above post represents my personal opinion.
Old 1/26/13, 3:18 PM
Michael Larson's Avatar
Not sure what is going on here.
Is that a clean out for the floor drain off to the left in the first pic?
That appears to be a main line cleanout plug below the water in pic #2
As a Professional Home Inspector, I support the privacy of my clients.
For more information click Trustyourinspector.ORG
www.InspectraPro.com
www.MinnesotaHomeInspector.biz
Michael Larson
Hudson, WI
Call me
Old 1/27/13, 7:22 AM
Yes, that is the typically clean out you will have in a 2002 build (Mikes inquiry)
Good advice Larry!!
Heading out in a few to do this particular inspection, appreciate the insight!!
Renovating Your Basement for Livability mkyriacou Canadian Inspectors 0 10/22/09 11:45 AM
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
gutter downspout to basement drainage system David Paterson Exterior Inspections 2 12/18/06 6:27 PM
