I inspected a home today that had a basement shower installed. The drain ran through the wall and out to a floor drain. Is this acceptable? What is your opinion?
Fast answer is no.
That should not be for waste. |
Thanks, my thoughts exactly. Was a new one for me.
Lots of times they go to the sump.
I agree it should not go to the floor drain. It should go to a sump or a grind pump depending upon whether or not there is also a toilet in the bathroom as well.
It's at least better than this one in a basement bathroom/shower.
Where is that drain anyway? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I meant it should not go to the sump, to make that clear.(as in clear water yuck)
Michael - Is that why they put the space between the boards.
Robert your right. The only drain you are allowed to in-direct is a floor drain. Sump is for storm not sanitary sewer. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
The water meter was under that bench in the pic I posted. I had a heck of a time finding it. No access to the shut off valve as the shower bench was nailed together. You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
yes wanted to correct my prev post, should not go to a sump just a grind pump of some sorts in most cases.
Ian , you must mean ejector pump.
We use them a lot in Illinois. Finished basements are big. Here is the direct link to a blog I wrote on my experiance.http://www.chicagopropertyinspection...#1194582223934 www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 5/6/08 at 4:12 PM.. |
Bill Corbett C.H.I. Magic City Inspections LLC InspectingtheUnexpected.com
We also called them sludge pump, a more graphic description, don't you think?
Is there a trap at all for that shower (you can't count the one in the floor)? In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
A more graphic description would be the picture I used on the site.
How about s--t pump |
| Inspector in hot water after approving unit without drain | rcooke | Canadian Inspectors | 7 | 2/20/08 3:59 PM |
| Shower Drain | thejnicki | Plumbing Inspections | 9 | 9/5/07 6:54 PM |
| gutter downspout to basement drainage system | David Paterson | Exterior Inspections | 2 | 12/18/06 6:27 PM |
