Old 5/27/10, 8:34 AM
Peter W. Bennett Peter W. Bennett is offline
Default Basement sump pump connected to Septic
got another first one the other day.
Is it ok to connect a sump pump discharge to a septic system?
thanks, pb
Need a home inspection in West Virginia? Check out InterNACHI's listing of West Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/27/10, 8:39 AM
arook arook is offline
Please Note: arook is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Basement sump pump connected to Septic
Typically it depends on the municipality.
I generally recommend re-routing to exterior and the use of a check valve (if there's not one already).
Old 5/27/10, 11:28 AM
James E. Braun, CMI's Avatar
It is not allowed in Missouri, including french drains. The system is only designed to handle so much water. Adding rain falls will overwhelm most systems.
Old 5/27/10, 1:58 PM
mnahrgang's Avatar
What Jim said. It might be "allowed" where you are at, but it's a terrible idea.
Mark Nahrgang
www.HeyMark.info
Old 5/27/10, 2:34 PM
Joshua L. Frederick Joshua L. Frederick is offline
Plumbing: Sump pump into sewage system
LOCATION(S): Crawlspace.
Sump pump routed into sewage system. Not a recommended practice. Septic systems are simple bio-reactors. If you pump too much water into them, that dilutes the micro-organisms and slows down their activity. Too much water too fast also flushes the "solids" into your weeping system, clogging it (costly). Recommend corrective action by rerouting discharge to the exterior grounds well away from the structure.
Old 6/2/10, 12:15 PM
Jim Kolke's Avatar
Jim Kolke Jim Kolke is offline
Joshua~ You definetly are on the mark. We can use french drains as long as pop ups are used with them.
Poly being applied to Basement walls dvalley Interior Inspections 40 11/24/09 10:49 PM
Renovating Your Basement for Livability mkyriacou Canadian Inspectors 0 10/22/09 11:45 AM
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
