Inspected a basement today with a sump, but no sump pump. Please explain to me how these sumps work. Where does the water come from and where does it go if no pump is provided?
Thanks.
What you have there is sump with a missing pump. Write it up.
Thanks James. I sort of thought that, and you confirmed it. How does the water get channeled to the sump? Drainage system beneath the slab that directs it to the sump? Never saw one installed. Limited knowledge about them in basements.
The pump will also have a grinder built in to the impeller. |
Joe,
Here's a better illustration...
Water seems to make it in most basements here especially a house over 20 yrs old.
J.Szczesny 4 Seasons Home Inspections Washington State Inspector # 711 800 5th Ave #101-385 Seattle, Wa 98104 (206)391-0285 online @ www.4seasonsinspects.com email @ info@4seasonsinspects.com toll free cal @ 866-512-9972 "For the best protection, get the right inspection" |
What about this thing: sump or ejector?
A pit in an expensive new home with an unfinished basement. Pit has a plate on it bolted shut.
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Actually, at least in our area, the lid means everything. The sealed and bolted ones (ejector-or sanitary- pumps) are that way to keep the sewage gases from entering the basement and the loose ones don't need sealing because they are simple sump pumps with no sewage gases. One of the holes in the top of the sealed ejector pump lid is for venting.
And vented to the exterior. Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Hmmm, I wonder why? It seems like overkill.
And how do you determine what its connected to if the lid is bolted shut???
Well Joe, if there is a bathroom which might not be able to drain with gravity to the main sewage line, chances are it's a grinder pump (sump)....but I would take the bolts off regardless to see if the foundation drain pipe is connected to the sump or if ABS Plastic sewage pipe is connected to the sump from a bathroom, laundry, kitchen, or what ever.
| Who is PA wants some work? | jkaylor | Green Building Inspections | 1 | 2/23/09 2:37 PM |
| Basement Waterproofing basics | mcyr | General Inspection Discussion | 8 | 8/28/07 5:53 AM |
| Basement Work Done In Past | Nick Scibetta | Structural Inspections | 18 | 10/31/06 4:21 PM |
