Old 12/4/08, 8:37 AM
Bruce L. Treacy Bruce L. Treacy is offline
Default Basement toilet bubbles from air
1940's house, 1 floor, toilet on first floor, install new toilet in basement,
cut into floor and cast iron waste pipe, y connected to main pipe. Main stack is original up to roof. When the toilet on main floor is flushed the toilet in the basement actually bubbles from air backup. Both toilets flush ok to remove waste. What is the problem and how do you fix.
Bruce
Old 12/4/08, 8:44 AM
David P. Valley's Avatar
Default Re: Basement toilet bubbles from air
Sounds like a venting issue to me. It's sucking wanted air from the basement area due to its proximity (being closer than the main vent). Too many bathrooms on one vent?
The main vent pipe might have to be upgraded to a larger pipe.
Old 12/4/08, 8:51 AM
Bob Elliott's Avatar
My exact first thought.
Old 12/4/08, 10:26 AM
David A. Andersen's Avatar
The new toilet is too low.
Fix: add a pump out.
BPI# 5015804
Old 12/4/08, 4:09 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Is it pushing air out or sucking air in??
Old 12/4/08, 4:57 PM
Chuck Evans's Avatar
A vent problem will typically cause it to suck air due to siphoning. If it's blowing bubbles it could be partially obstructed sewer line or a low spot / trap in the sewer line which would allow air pressure to build up when the higher toilet is flushed. A partial obstruction in the line could cause it to either blow or siphon or even blow then siphon.
Try filling a tub and letting the water go. See if that causes a reaction as the tub empties (be prepared to stop it if it backs up through the toilet). If water rises in the toilet, the sewer line is probably obstructed.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 12/5/08, 9:41 PM
Andrew Cox Andrew Cox is offline
Cover the toilet with Saran wrap. If it expands, it's blowing air, if it pulls in, it's sucking air. I don't know what to do with the information, but it sounds like a cool experiment!
Andy Cox
http://www.CoxInspections.com
Kissimmee, FL
You’re Your Own Job Security.
Old 12/6/08, 1:12 AM
Lot's of good ideas as to what the problem is, but I know how to fix it. Call a plumber.
Old 12/6/08, 9:00 AM
Whatever is most cost effective...........
BPI# 5015804
Old 12/6/08, 12:12 PM
David P. OKeefe's Avatar
David P. OKeefe David P. OKeefe is offline
That sounds like a college dorm prank.
David
InterNACHI #08051301
NYS Lic. #16000038229
NYS DEC Cert # T4865884
518-505-8305
HouseAbout Home Inspections
HouseAbout on Facebook
NY Capital Region Chapter InterNACHI
something else to chew on john bubber Structural Inspections 706 4/25/12 7:13 AM
Site grading and drainage wdevries Canadian Inspectors 5 10/6/09 10:23 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
Basement Toilet Troubles mharvey2 Plumbing Inspections 1 11/23/06 3:52 PM
