Old 3/14/07, 9:39 PM
sfalvey sfalvey is offline
Default Bathroom vent--Lack of
Inspected a 18 mo house today. Both full bathrooms upstairs are missing venting by way of fan. The buyer told me, the agents told her, it is not needed because there is a window
This is one of those towns where there is not a building inspector.
Now, I am not a code inspector, but as far as I know, isn't this code.
Thanks.
Scott Falvey
Clear View Home Inspections, LLC
Newbury, NH
NACHI#05051292
www.clearviewhomeinspectionsllc.com
Old 3/14/07, 10:07 PM
Marc D. Shunk's Avatar
Banned
Default Re: Bathroom vent--Lack of
IRC 303.3 states that the minimum ventilation for the bathroom is to be a window of at least 3 sq. ft. of which 50% is operable, or a mechanical ventilation system of at least 50 cubic feet per minute (cfm) ducted to the outside.
303.3 Bathrooms.
Bathrooms, water closet compartments and other similar rooms shall be provided with aggregate glazing area in windows of not less than 3 square feet (0.279 m2), one-half of which must be openable.
Exception: The glazed areas shall not be required where artificial light and a mechanical ventilation system are provided. The minimum ventilation rates shall be 50 cfm (23.6 L/s) for intermittent ventilation or 20 cfm (9.4 L/s) for continuous ventilation. Ventilation air from the space shall be exhausted directly to the outside.
Old 3/14/07, 10:20 PM
James H. Bushart's Avatar
Thanks.
This is one of those cases where code is contrary to common sense.
During a January blizzard in subzero temperatures, very few folks are taking showers with the bathroom window open. Write it up as a condition conducive to moisture damage. Tell the agent to suck an egg.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 3/15/07, 10:27 AM
cshipman cshipman is offline
Help,, ,,,Water heater under new house installed on ground,, we wrote it up, builder says go fly a kite, show me wher it says has to be on pad! can't find it in code, anybody, Thanks,,
Old 3/15/07, 10:41 AM
Michael R. Boyett's Avatar
2003 IRC M1305.1.4.1 - Ground Clearance. Appliances supported from the ground shall be level and firmly supported on a concrete slab or other approved material extending above the adjoining ground. Appliances suspended from the floor shall have a clearance of not less than 6" from the ground.
The 2003 IRC may or may not be applicable in your area, you need to check.
Old 3/15/07, 12:29 PM
kkenny's Avatar
kkenny kkenny is offline
I agree w/ James,
Our clients hire us for our professional opinion as well as our expertise. It doesn't always matter that code is followed to the letter; code isn't always common sense.
Kevin
Kevin M. Kenny, Sr.
Kenny Home Inspections
Oak Forest, Illinois 60452
Nachi #6070990
http://kennyhomeinspections.com
Old 3/19/07, 4:17 PM
dmcauley's Avatar
dmcauley dmcauley is offline
Please Note: dmcauley is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would check with the manufacturer to see if this is allowed. Manufacturer installation and/or instructions supersedes all codes. We're talking about the water heater here.
Old 3/19/07, 9:42 PM
You've given your opinion - written your report. Its not up to you to fight their fight, thats up to them. Give them ammo, then move out of the way.
Finding bathroom vent terminations (under the insulation) kshepard Interior Inspections 26 11/5/07 5:40 PM
Bathroom vent cmettel Inspecting HVAC Systems 4 6/19/07 9:59 PM
Gas and oil hot water tank and Boiler Share Vents hvanderbeek Miscellaneous Discussion for Inspectors 8 1/25/07 5:22 PM
Soot around the bathroom vent lclark Exterior Inspections 7 3/6/06 8:13 AM
