Danny Castellano is a non-member guest and is in no way affiliated with InterNACHI or its members.
I have been running into a lot of tubs without drain traps, are they required? The one's I have not seen them on were on slab foundations with access panels. Could they possibly be located below the ground?
If you can't see the drains, how do you know they aren't trapped? Yes they are required.
Most traps in a slab on grade installation will be below the surface of the slab unless the tub is installed on a platform. |
| Child eviscerated by pool drain | mthomas2 | Ancillary Inspection Services & Additional Topics | 26 | 7/16/07 5:27 PM |
| Illegal traps | dmacy | Plumbing Inspections | 1 | 5/22/07 11:19 PM |
| Air leak from floor drain | yolhovsky | Plumbing Inspections | 5 | 2/24/07 7:43 AM |
| French drain tied into main drain | rwashington | Plumbing Inspections | 6 | 2/17/07 12:04 AM |
| condensate drain | lprinzi | Inspecting HVAC Systems | 3 | 8/11/06 6:57 PM |
