cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
That's the disinfecting type
</IMG> IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Yes skin and "all". </IMG> 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Just curious as to what made you take the temperature at the bidet and not the sink, unless, of course, the hot and cold water lines were reverse.
Water temp was too high at the sink----got to thinking it might be a good idea to check the bidet
Charles,
As Jeff stated, that water coming from that area is hot for disinfecting the bowl which is not an issue. The supply (at the front) should be the cooler water. When you turn it on, put your face over it...... |
David, I think Jeff was kidding
I don't know of anyone that washes their face in a bidet do you? </IMG> 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
Some fixtures have Mixing Valves for single fixture [point of use] and some can control temp. 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
I was simply joking about putting your face over the fountain. You all know what that spout at the front is meant for... |
How the hell are you going to wash your body parts with a very hot waterfall at the rear of the toilet? |
So David, are you saying it is OK to have 143 degree water at the "geyser" part of the fixture?
I'm no expert on Bidet use but I believe the two supplies are separated. In your pic you have the flush/sanitizer running with one control and the supply is controlled with a separate control... am I right? I would imagine the cleansing supply is on a mixing valve. Now, if you had your infrared pointing at the supply valve area with that temperature, I'd say you'd have a problem. |
And you don't know me. It really is hard to communicate on a MB. Just messing with you!! 'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
| Ouch!! | dmacy | Exterior Inspections | 5 | 11/15/06 11:21 AM |
| Odor From Bidet | dbreen | Plumbing Inspections | 3 | 11/13/06 6:04 PM |
| Ouch | jbushart | Miscellaneous Discussion for Inspectors | 6 | 8/23/06 4:41 PM |
| Homemade bidet!?!? | mmorgan | Plumbing Inspections | 12 | 7/8/06 4:08 AM |
| Deck on Garage (New Construction).. OUCH | pbolliger | Electrical Inspections | 1 | 4/19/06 9:25 PM |
