I have never seen this before. Needless to say I did not run very much water down any of the drains.
"Never ever threaten anyone in Camoflage" Tim Wilson "Not everyone follows the same path" Governor Sanford, musings on the Appalachian Trail
| Find an InterNACHI certified District Of Columbia Home Inspector (and anywhere else in North America) |
Wow, never seen that. You guys play hardball.
Keith Runquist, CMI |
First for me as well Keith
WOW, disconnected from SEWER. As if water and electricity shut-off wasn't enough.
That'll force them to leave the house. Hmmm, this is the first I've seen this. |
How is it disconnected? Did they put a block in that cleanout? Never seen this? Will the water backup into the house?
David INACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert#T4865884 www.houseabouthomeinspections.com |
Guess I didn't know you could "disconnect" a sewer connection.
I'd like to see a photo of what they considered "disconnected" Steven Waskewicz Rest Assured Inspection Services, LLC. 12615 Halleluiah Trail Elbert, Colorado 80106 Office 719-510-7703 mobile all the time Fax 719-495-7166 Serving Colorado Springs, and surrounding areas. www.restassuredinspection.com s_waskewicz@msn.com NACHIiid=NACHI06032370 |
I imagine they put an expandable pig down in the cleanout Steven.
MULTI SIZE PNEUMATIC PIPE PLUGS Multi Size Pneumatic Pipe Plugs are designed for use in a wide variety of pipe types and styles as well as job requirements. Some advantages would include: Not needing to know the exact pipe size Will work in a variety of pipe sizes Will seal most slightly out of round pipes Excellent for standard low pressure air testing. Contractor Ready air test package available.Use also for blocking or leak locating Standard multi sizes from 4" to 96"
"Never underestimate the difficulty of changing false beliefs by facts." |
| Blocked Supply Ducts? | thance | HVAC | 7 | 8/18/09 10:45 PM |
| Granite Inspections pay schedule | mhazelwood | Misc. Discussion | 0 | 11/28/07 3:18 AM |
