Old 10/6/06, 10:23 PM
Default Bonding both hot and hold supply pipes
I almost never see the hot and cold pipes bonded together at the water heater. I often see one or the other but it seems to me there ought to be a jumper between the two. Is this an AHJ issue?
Director of Green Building
EXPERT WITNESS SERVICE
Conventional and Log homes
(303) 717-8940
Old 10/6/06, 10:34 PM
Default Re: Bonding both hot and hold supply pipes
No it is a requirement:
See 250.104(B) Other Metal Piping
Old 10/12/06, 12:40 AM
Well I virtually never see a jumper to the hot water piping and almost never see the hot pipe bonded. Do you see it bonded correctly at the hot water heater most of the time? Anybody? Anywhere?
(303) 717-8940
Old 10/12/06, 12:59 AM
Brian E. Kelly's Avatar
Predominantly bonded @ the water heater correctly.
Old 10/12/06, 6:05 AM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
JOE,
was this just added/changed for the 2005 NEC?
KENTON,
I would say that 80+% of the homes (with metal pipes) I inspect do NOT have jumpers!
Old 10/12/06, 3:06 PM
Barry Adair's Avatar
This was bonding from cold water supply clamp for WH flues, chimneys, gas piping, and the jumper for H/C water supplies at the twin WHs at a new build in Frisco, TX this year. This is the only one I've seen done this way so far. The WHs did have dielectric unions.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/12/06, 3:10 PM
I just finished discussing this with inspectors at the local building department who told me that it's a matter of interpretation. They require the cold water pipes to be bonded, preferably to the grounding bus bar in the main panel or to a grounding electrode rather than the water pipes because plastic main water lines are sometimes used underground here. They recommend bonding the hot water pipes but they don't call it a defect if they don't see it.
(303) 717-8940
Old 10/12/06, 3:17 PM
Michael Larson's Avatar
Barry,
Are the water pipes bonded as well?
I can't tell from your picture. I only see the flues bonded to ground.
Is there any chance this is for lightning?
I have never seen this has anyone else?
Old 10/12/06, 3:20 PM
Hypothetical questions about previous post.
With this flue bonding set up could the roof exposed flues become "lightning rods" and electrocute someone showering, let's say standing in a metal tub, touching the plumbing control knobs?
Or would the strike always go back to ground?
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 10/12/06, 3:23 PM
Lightning strike or home current getting onto the pipes accidently. That was my concern.
(303) 717-8940
Old 10/12/06, 3:27 PM
Michael,
As posted this WAS BONDED clamped at cold supply entry to this house.
I can't locate the H-C jumpers photos right now but I am seeing H-C jumpers more often on new builds. Not all but they are out there.
Others,
Please reply to post #9
ADAIR INSPECTION
972-487-5634
TREC # 4563
Old 10/12/06, 3:54 PM
Jeffrey R. Pope's Avatar
The bonding of those vents does nothing and is not required. The draft hoods do not make a good enough connection to even bond the tanks.
I see no hazard with this setup, but I see no benefit either.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 10/12/06, 11:52 PM
Originally Posted by srowe
JOE,
KENTON,
Checking earlier editions will show the same words around the Section 250-80 area, and the following has been in the NEC for many years:
FPN: Bonding all piping and metal air ducts within the premises will provide additional safety.
Old 10/13/06, 12:21 AM
I spent about 20 minutes talking with the county building inspectors, they were pretty relaxed and they'd been discussing it between themselves for a few minutes before they finally called me in.
I told them I was concerned about safety and liability and they just kind of rolled their eyes and in the ensuing discussion it was plain that so were they but that grounding and bonding (they made it plain) were one of the most difficult issues to nail down, Things keep changing and are different in different jurisdictions.
Around here, I think the main issue is that you're recommendations must be written to keep people safe and your knowledge must be on a par with local practices generally accepted by local building officials.
(303) 717-8940
