Old 8/27/08, 5:35 PM
Default Bottle Traps
Anyone know of any issues with these Bottle style traps? Are they approved as a replacement to a standard P-Trap?
http://www.amazon.com/Decolav-Decora.../dp/B000LSJ1MO
Kevin
Kevin A. Richardson
Level III Infraspection Institute Certified Infrared Thermographer®, #7493
301-942-4610
www.richnspect.com
www.infrared-diagnostics.com
www.thehomegreenteam.com
Old 8/27/08, 5:41 PM
Michael Larson's Avatar
Default Re: Bottle Traps
They have been discussed here several times.
Your AHJ would have to approve their use.
More Here
Please note that bottle traps (all brands) may not be per code (meaning they may not be legal) in your area.
It would be best to check with your local plumbing code before purchasing and installing them.
Bottle traps are used in many countries as the "standard" trap but not in the U.S.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 8/27/08, 5:52 PM
gbeaumont's Avatar
Hi Kevin,
I believe that that trap is not really a bottle trap in the real sense of the word, rather it is an enclosed P trap which would be allowed in most if not all jurisdictions.
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 8/27/08, 6:00 PM
Originally Posted by gbeaumont
Hi Kevin,
Regards
Gerry
Gerry, What Kevin posted appears to be a bottle trap.
Here is a drawing. The partition can corrode and loose the trap seal.
http://www.freepatentsonline.com/7155760-0-large.jpg
Do you have any links to what you are calling an enclosed P-trap?
Michael Larson
Hudson, WI
InspectraPro
and
Old 8/27/08, 6:02 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
UPC (Uniform Plumbing Code) generally prohibits drum traps.
1004.0 Traps – Prohibited.
No form of trap which depends for its seal upon the action of
movable parts shall be used. No trap which has concealed
interior partitions, except those of plastic, glass-or similar corrosion-
resisting material, shall be used.
"S" traps, bell traps,
and crown-vented traps shall be prohibited. No fixture shall
be double trapped. Drum and bottle traps may be installed
only when permitted by the Authority Having Jurisdiction for
special conditions. No trap shall be installed without a vent,
except as otherwise provided in this Code.
Old 8/27/08, 6:42 PM
Thanks Robert!!
Here is the pic of the trap that was installed below a Hall Bath sink in a Condo I inspected this morning.
This basement condo unit also had two bedrooms without any means of secondary egress.
Kevin
Kevin A. Richardson
301-942-4610
www.richnspect.com
Old 8/27/08, 7:41 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
Not approved around here except in laboratory use (Don't know why even there). They can be made of ceramic too, ran into a couple of those for chemical sinks.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 8/27/08, 8:00 PM
relliott's Avatar
I have never seen then (or at least noticed them) in a hardware store , but imagine they cost more.
If I was putting one in despite code, it would be for looks , which really do not matter under an enclosed cabinet.
Old 8/27/08, 8:12 PM
gbeaumont's Avatar
Hi Mike the true bottle traps are bottle shaped and do not have the same internal layout of the one Kevin showed, having said that given Bobs IRC quote I can still see them being problematical.
Regards
Gerry
(Mark B Adams)
NACHI02121106
Old 8/28/08, 12:03 AM
Hey if you ever tried to unstop one you'd know why they are not legal. Bottle or drum traps are a plumbers night mare.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 8/28/08, 12:53 AM
relliott's Avatar
Nah.
Just unscrew and replace.
Getting back your ring is another story.
Old 8/28/08, 10:47 PM
Rehabed a 1920 vintage 2 story double with 1/2 basement 1/2 6" crawl. Bath and kit. sink went below floor (which we ended up pulling up) to replace traps. really was a nightmare.
Didn't find any Rings.
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Illegal traps dmacy Plumbing Inspections 1 5/22/07 11:19 PM
Bathtub drain traps Danny Castellano Plumbing Inspections 1 10/5/06 2:25 PM
Air Admittance valve? 2 traps aharper1 Plumbing Inspections 5 9/24/06 8:42 PM
2 Traps at Kitchen Sink pdickerson Plumbing Inspections 15 2/6/06 9:56 PM
