FYI -
Another class-action suit has been filed for failures of brass fittings in PEX systems installations. http://www.uponorlawsuit.com/index.html IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Need a home inspection in Utah? Check out InterNACHI's listing of Utah certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
ty for the info...here we go again...
Comprehensive Building Consultants Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection. Donate here: or send checks to the Fl Home and Insurance Inspector Chapter 1103 W Hibiscus Blvd Ste 311 Melbourne, Fl 32901
Whats in the water up there???
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
So these are not the same QPEX fittings?
Vince Santos
StepByStep Home Services LC (734) 748-9584 Providing Home Inspection Services to Southeast Michigan ITA Trained and Certified |
That bites, I LOVE the PEX system
They have fittings other than brass, which have had no reported failures.
And the funny thing is I was using the Brass fittings exclusively because I thought they were a better product.
There a many brands of Pex brass fittings. Not all fail.
J.Szczesny 4 Seasons Home Inspections Washington State Inspector # 711 800 5th Ave #101-385 Seattle, Wa 98104 (206)391-0285 online @ www.4seasonsinspects.com email @ info@4seasonsinspects.com toll free cal @ 866-512-9972 "For the best protection, get the right inspection" |
Exactly...
The fittings from http://www.uponorlawsuit.com/index.html are identified by: Quote:
That was never implied.
This may have confused some: Quote:
Sorry for any confusion...
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
While it is true that it was brass fittings that were failing in the lawsuit, the plastic fittings are fine, IF they are properly installed. Failure in plastic fittings comes from the improper installation and not the product design. And, while the system may look good and have plastic, beware, are you sure it installed properly by the technician who did the job? I love these systems, uh huh.
I built my home in 2004, all with white ZURN-PEX lines. Connectors and elbows are all brass. Crimp rings are copper, stamped with PEX on the rings. System has watts pressure regulator set at 62 lbs. No problems so far. T-connectors are marked SOM-PEX. Half inch elbows are marked "PEX-F-1087-NSF61. Three quarter elbows are "3/4 PEX-NSF-PW-Korea AH.U".
CMI, CPI, KS #0110-0094 Termite #16601 KS Radon #KS-MS-0027 BBB A+ Accredited Business Serving the Greater Kansas City Metro Area Eastern Kansas/Western Missouri http://www.metrospeckc.com "If opportunity doesn't knock, build a door"--Milton Berle Last edited by gfarnsworth; 11/29/10 at 4:56 PM.. |
| Interesting article about mold by litigation. | gromicko | IAC2 Indoor Air Forum | 16 | 5/5/11 7:48 PM |
| MJ fitting on ABS | rmisener | Plumbing Inspections | 3 | 2/27/09 5:36 PM |
| Contractors suggesting litigation | dmacy | Miscellaneous Discussion for Inspectors | 18 | 7/5/07 10:18 PM |
