Greg Sullivan is a non-member guest and is in no way affiliated with InterNACHI or its members.
This is a follow up post to a thread I started in the structural section of this forum.
To try and eliminate the water heater as a source of heat in my garage floor, I had closed the 16 year old gate valve on the inlet pipe to the water heater. I thought the valve was fully closed when it was not. Then, when I tried to open the valve to resume normal flow, the handle just spun freely. The valve stem had snapped off inside. The damaged gate was stuck closed and only let a small amount of water though the damaged portion of the gate. This made taking a shower a bit difficult. I am not a home inspector (yet), but I have learned from reading the posts in this forum that opening or closing old valves can be risky. In fact, I noticed that most home inspectors will not touch the main water supply cutoff valve. My experience with the water valve on my water heater reinforces that wisdom. I've attached a picture of the corroded interior of the old gate valve. It was replaced with a new ball valve. Regards, Greg Sullivan / Canyon Lake, CA. Last edited by Greg Sullivan; 3/22/06 at 11:46 AM.. Reason: Adding another picture |
I never operate any valves, heck, I'm a little worried about door handles now, one fell off in my hand the other day
"If God was one of us, would he recommend a detailed analysis by a structural engineer for the world?" Michael S. Saxton http://www.duluthhomeinspections.com |
golden rule of plumbing..... snug is tight, tight is broke.
| TPR valve | acox | Plumbing Inspections | 19 | 5/27/07 12:36 PM |
| Backwater valve in new homes? | ccrooker | Canadian Inspectors | 16 | 11/28/06 7:47 AM |
| Moen Shower Valve - No Retainer Clip Slot | Zemke | Plumbing Inspections | 7 | 9/24/06 10:02 PM |
| Water Heater Pressure Valve | wrosario | Plumbing Inspections | 3 | 7/7/06 7:27 PM |
| Broken Window seals | dedwards | General Inspection Discussion | 0 | 2/17/06 3:19 PM |
