Old 10/12/07, 9:44 AM
Gary W. Bowe Gary W. Bowe is offline
Please Note: Gary W. Bowe is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Broken Pipe Removal
I would appreciate any ideas on how to remove a short threaded section of plastic (PVC) pipe that has broken off inside a brass elbow fitting. While searching for a leak, I removed the bath tub spout (with shower diverter) and discovered it was connected to the elbow fitting via a PVC nipple/pipe. While I was attempting to remove the PVC, it snapped off about halfway inside the fitting. Of course, the fitting is inside the wall behind ceramic tile on a mortar and mesh bed with a very small opening around it. Any ideas on how best to remove the remaining pipe without damaging the fitting threads would be greatly appreciated.
Old 10/12/07, 9:56 AM
Michael Larson's Avatar
Default Re: Broken Pipe Removal
Use a small saw(coping blade or hack saw blade) to cut a slot in the broken plastic nipple. Be careful not to cut into the thread of the el fitting. Then use an awl or a long thin screwdriver to pry the remaing plastic out. Cut the slot on top of the fitting. If you don't feel confortable with this, call a plumber.
Old 10/12/07, 10:33 AM
Thanks.
Old 10/12/07, 10:53 AM
For just a few dollars.
This works well.
Marcel
Old 10/12/07, 11:18 AM
Thanks. I have that extractor, but there isn't enough depth in the fitting to get the tapered tip to bite the inside of the pipe.
Old 10/12/07, 3:26 PM
cbuell's Avatar
cbuell cbuell is offline
Please Note: cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
you can also glue another smaller piece of pipe inside the broken off piece.
Old 10/12/07, 6:18 PM
Brian E. Kelly's Avatar
http://www.plumbersurplus.com/Prod/D.../59845/Cat/655
Old 10/12/07, 6:26 PM
Originally Posted by bkelly2
Brian, can Gary just borrow yours?
Old 10/12/07, 6:34 PM
Roy D. Cooke, Sr's Avatar
Yes he explained it well Have done this Many Many times .
When you get is started a pair of needle nose pliers and just turn it inside it self and out it comes .
. ... Cookie
Old 10/18/07, 6:00 PM
Thanks.
Old 11/1/07, 2:31 PM
Phil J. Sefzik Phil J. Sefzik is offline
Use a wood chisle smaller them the pipe. Drive it into pvc pipe with the flat side going to right. If you can't turn by hand use cresent wrench on
blade of chisle, works like a charm.
Do you put polybutylene in the Summary? jfunderburk Plumbing Inspections 41 4/5/12 6:43 AM
Help - Polybutylene Pipes Rick G Plumbing Inspections 39 2/12/09 8:16 AM
Identify ABS defective pipe mcyr Plumbing Inspections 6 1/29/09 6:39 PM
Asbestos jlybolt Exterior Inspections 41 7/17/07 1:13 AM
