Can PVC Pipe be used in attics as a water supply line? Even if it is insulated?
IRC and UPC indicates that PVC Plastic Pipe is OK for service, just not for distribution.
Brian R. Sumpter First Call Inspections Proudly serving most Bay Area Counties www.firstcallinspections.com |
PVC is allowed for cold water distribution outside of the building. If it's insulated, I'd bet that it's being used for hot water distribution.
CPVC (as Michael mentioned) can be used for hot and cold. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I see PVC used for service entry all the time. As for Hot/Cold distribution, we normally see CPVC or Copper in our neck of the woods.
What I don't see, is insulation on service or distribution lines, on any kind of regular basis. I always recommend to my clients to consider insulating these lines as an energy conserving addition to the system. |
I believe that pvc is rated up to about 140 degrees (CPVC-180), I don't know about New Mexico but here in Florida I have seen attics over 140.
************************************** Shawn Rowe, CMI HomeFirst Inspection Services, LLC - InfraRed Specialist (Level 1 & Building Science certified) - Code Certified Residential Building Inspector - Certified Master Inspector -- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties -- |
twasion is a non-member guest and is in no way affiliated with InterNACHI or its members.
In Iowa I plumbed under the UPC and PVC or CPVC was illegal to use. PVC expands and contracts quite a bit so I sure would not want to use it for any water under preasure (even Schedule 80) and certainly not in cold climates.
| Ventilated or Non Ventilated Attics | phughes | Structural Inspections | 8 | 11/29/07 9:24 PM |
| AZ Attics | cvowell | General Inspection Discussion | 4 | 7/15/07 1:25 AM |
| Straw Poll re Attics | bsilowash | Interior Inspections | 32 | 4/29/07 9:10 PM |
| Water heaters in attics | phughes | Plumbing Inspections | 1 | 1/11/07 12:08 PM |
