Can you find the defect that the local buiding inspector made the waterproofing company install at the sump pump?
I had an interior drainage system installed the last 3 days. The pump is a zoeller with a hydro pump back up. Last edited by dmacy; 10/28/08 at 7:37 PM.. |
It will work better if they plug in it.
Alex,
I will take, what is a check valve? for $200.00 Please 1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think I see two check valves, so this is OK. I can't see a GFCI protected receptacle though. I fitted one to supply my sump pump recently. So I'll take what is a GFCI? for $1000 please.
And Zoeller are brilliant sump pumps. I recently replaced my last one. It was 15 years old (they are date stamped), very rusty but still working. Brilliant. And because the designs have not changed much, new ones drop straight in! My sump pump is cast iron. Bronze ones look beautiful but cost a fortune. Why are they so expensive? Corrosion resistance? I'm not an HI. Last edited by Ian Gills; 3/21/07 at 5:44 PM.. |
And the answer is.
Back flow preventer is needed on the water back up pump. |
Ah, I can taste that sump discharge now. Mmmmmmm.
The GFCI is a dedicated circuit. It techanically should have only one receptacle & not two. If I had a battery back up then the two recpetacle GFCI would be fine. I dont plan on using if for anything else.
I also spoke to PAbernathy and he likes the GFCI better in this scenerio. The city inspector was OK with the GFCI. |
| Is inadequate roof or attic ventilation a defect? | gliebig | Exterior Inspections | 85 | 1/16/08 6:56 PM |
| Preemptive Spark Helps Find Electrical Short Circuits In Airplanes | mbledsoe | Electrical Inspections | 0 | 6/21/06 2:30 PM |
