Can you see the problem with this water heater setup from today's inspection??
Mike Morgan Central Texas Home Inspections mike@centraltexashomeinspections.com www.centraltexashomeinspections.com |
Yes, I can.
piercing type saddle valve tapped into flexible section for which it is not designed. Saddle valve tapped onto hot water (this is done sometimes to get clearer ice cubes). Piercing valves suck.
He just asked if I could see it, not for an explanation...
However, that is what I found, both issues. I used to use those things years ago, but return calls for leaks on over 50% of them caused me to use soldered fittings, valves and compression fittings instead. End of leaks. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
It appears that the vent is to large for the collar.
No visible bonding jumper (assuming metallic piping), no TPR valve (limited picture view) and the saddle (piercing) fitting. Anything else? IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
I'll stick with the improperly sized vent! Jeffrey Wortham ANS Inspections, Inc. www.ansinspections.com 630.276.8440 638 Langford Drive Bolingbrook, IL 60440 NACHI ID:04050181 |
brepanshek is a non-member guest and is in no way affiliated with InterNACHI or its members.
Are you sure this is wrong size vent???? Looks like b-vent (doubled wall pipe) which makes it look bigger than needed.????? just a thought
Vent requires 3 screws per connection...didn't see any holding the vent to the draft hood.
Darrell Hadler CMI Five Star Home Inspections Medicine Hat, AB. Canada NACHI# 04111082 Cell phone# (403)502-3593 Inspected once . . . inspected right! (website) http://inspectorpages.com/dhadler
How about the kink in the hot water outlet and it might not be code,but shouldn't there be Di-electric union?
Paul Tos is a non-member guest and is in no way affiliated with InterNACHI or its members.
Hot water tap (anodizing bacterial issues if feeding power humidifier / ice maker, etc.)
B-vent OK (3 screw rule may not be possible now - not supposed to penetrate inner wall) - better install would have been 6-12" of single wall into the double wall (would have also allowed for future change outs. Looks like a new piece of b-vent - where does it terminate - if to outdoors - are proper clearances maintained thru run - is insulation shield installed in attic. dielectric ? 18 in rule required? |
| Fetchreport.com Email Problem | jmckenna1 | Miscellaneous Discussion for Inspectors | 13 | 11/1/07 11:50 AM |
| Is MAC a problem | bemelander | General Inspection Discussion | 2 | 9/6/07 12:34 PM |
| Camera Problem | nwagner | Miscellaneous Discussion for Inspectors | 19 | 7/30/07 11:10 PM |
| Plumbing problem at home. | mnahrgang | Plumbing Inspections | 25 | 7/10/07 6:32 PM |
| Spot a Problem | cradan | Electrical Inspections | 10 | 7/14/06 11:14 PM |
