WANTED:
Instructors who can teach the following courses, and either have their own curriculum or can develop it by March. Plumbing & Pipefitting for Plants & Buildings https://www.americantrainco.com/trai...ourse&coid=151 Steam Systems Maintenance, Safety & Optimization™ https://www.americantrainco.com/trai...ourse&coid=152 If you can do this, or know someone who can do this, please direct them to me. |
Call my friend Don Krische, Joe @ 480-203-5654.
Thanks for the lead!
Haven't seen you around...hope life is treating you good, Joe.
Same to you, I am doing great and I am still on the road, now teaching the 2008 NEC. Last edited by jtedesco1; 11/18/07 at 11:08 PM.. |
Joe,
Good to hear from you again!! Glad to hear all is going well! You know we miss you here! Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
Question: Have there been any grounding and bonding issues discussed or changed related to CSST "Corrugated Stainless Steel Tubing" used for gas supplies? |
http://www.nahb.org/news_details.aspx?newsID=5144 InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Here on the NACHI board: http://www.nachi.org/forum/showthrea...highlight=csst How about jumping in on the discussion? We can always use an expert's inside view! Knowledge is power, but sharing knowledge brings peace! http://www.psinspection.com TREC License# 7593 Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC! |
Thanks Larry, I see where the NAHB is proposing a rule for the 2011 NEC covering this issue.
There are lots of files available on the CSST issue here. |
"A Tentative Interim Amendment is tentative because it has not been processed through the entire standards-making procedures. It is interim because it is effective only between editions of the standard. A TIA automatically becomes a proposal of the proponent for the next edition of the standard; as such, it then is subject to all of the procedures of the standards-making process."
Good to see you back on the NACHI BB! Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 |
I was wondering if they ever plan to update this NH Code?
CHAPTER 187 SB 81- FINAL VERSION 04/12/07 1176s 2007 SESSION 07-0556 05/03 SENATE BILL 81 SPONSOR S: Sen. Clegg, Dist 14; Sen. Downing, Dist 22; Sen. Letourneau, Dist 19; Sen. Gatsas, Dist 16; Rep. Goley, Hills 8; Rep. Infantine, Hills 13; Rep. Carson, Rock 3; Rep. Patten, Carr 4AN ACT relative to the state building code. COMMITTEE: Executive Departments and Administration AMENDED ANALYSIS The bill updates the definition of the state building code. - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - Explanation: Matter added to current law appears in bold italics. Matter removed from current law appears [in brackets and struckthrough.] Matter which is either (a) all new or (b) repealed and reenacted appears in regular type. 04/12/07 1176s 07-0556 05/03 STATE OF NEW HAMPSHIRE In the Year of Our Lord Two Thousand Seven AN ACT relative to the state building code. Be it Enacted by the Senate and House of Representatives in General Court convened: 187:1 Definition of Building in the State Building Code. Amend RSA 155-A:1, I to read as follows: I. “Building” means building as defined and interpreted by the International Code Council’s International Building Code [2000] 2006. 187:2 Definition of State Building Code. Amend RSA 155-A:1, IV to read as follows: IV. “New Hampshire building code” or “state building code” means the adoption by reference of the International Building Code [2000] 2006, the International Plumbing Code [2000] 2006, the International Mechanical Code [2000] 2006, the International Energy Conservation Code [2000] 2006, and the International Residential Code [2000] 2006, as published by the International Code Council, and the National Electric Code [2002] 2005. The provisions of any other national code or model code referred to within a code listed in this definition shall not be included in the state building code unless specifically included in the codes listed in this definition. 187:3 Definition of Structure in the State Building Code. Amend RSA 155-A:1, VI to read as follows: VI. “Structure” means structure as defined and interpreted by the International Code Council’s International Building Code [2000] 2006. 187:4 Effective Date. This act shall take effect 60 days after its passage. Approved: June 18, 2007 Effective: August 17, 2007 Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 Last edited by fcarrio; 11/19/07 at 5:54 PM.. |
Joe,
When will the 2005 NEC be updated? the National Electric Code [2002] 2005. The provisions of any other national code or model code referred to within a code listed in this definition shall not be included in the state building code unless specifically included in the codes listed in this definition. Signed, Frank Carrio, CMI Certified Master Inspector & Consultant Certified Commercial Building Inspector Certified, WDI Inspector Founder & Current President, New Hampshire State Chapter NACHI NACHI, State Representative for Legislative Affairs Retired: ICC Certified Member Retired: Code Compliance Inspector. Retired: ASTM Committee Member New Hampshire License #0096 |
| New York State Education Conference | bmerrell | Inspection Education & Training | 43 | 12/25/06 9:10 PM |
| Industry icon to help teach CMI courses. Formerly with New York Giants. | gromicko | Miscellaneous Discussion for Inspectors | 0 | 6/3/06 4:14 PM |
| Upcoming IAQ courses in Canada. | gromicko | Canadian Inspectors | 1 | 4/3/06 7:23 PM |
| Gerry Beaumont to teach advanced courses for NACHI. | gromicko | Miscellaneous Discussion for Inspectors | 20 | 1/25/06 11:47 AM |
