Old 5/20/08, 11:43 AM
Spencer B. Johns's Avatar
Spencer B. Johns Spencer B. Johns is offline
Default Can you use copper Flex
Can you use copper flex pipping for the TPRV drain line. It extends down for about a foot connects to regular copper pipping and then out to the exterior.
First time I have seen this.
Old 5/20/08, 11:49 AM
Bob Elliott's Avatar
Default Re: Can you use copper Flex
I personaly would not have a problem.
Old 5/20/08, 12:01 PM
Michael Larson's Avatar
If it's 3/4" and not kinked I would have no problem with it.
Michael Larson
Hudson, WI
Old 5/20/08, 4:08 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
See the TPR mini course.
http://www.nachi.org/waterheaterdisc...leased2007.htm
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 5/20/08, 5:26 PM
Michael R. Boyett's Avatar
Technically, the answer is No, you should not use the common flexible water supply connector such as a BrassCraft BD00 but you do see it quite often. As an example, a typical Cash Acme T&P valve will discharge at a pressure of 175 psi and/or a temperature of 210°F. The BrassCraft flexible copper connector is rated at 125 psi at 180°. So, you can easily see where the water being discharged could exceed the operating characteristics of the flex connector. The argument, although weak, is that the temperature and/or pressure would only be present for a short period of time. Well, that's the rub isn't it? How long is too long? 1 second, 10 seconds, a minute? I admit that it does make for a nice looking installation but I'm of the opinion that it is not proper.
Here's a snippet from the BrassCraft catalog re: copper flex connectors:
Old 5/20/08, 5:49 PM
The pressure you speak of does not account for the fact there is flow.
If it was flex on its own I would be more concerned with movement of the pipe.
175 is the pressure if capped
Old 5/20/08, 8:44 PM
Describe exactly what you mean by flex. Are you talking soft copper or other and how is it connected to the hard copper?
Jack Gilleland
jgilleland1@att.net
linkedIn
activerain
Old 5/21/08, 12:22 AM
Russel Ray's Avatar
In my neck of the woods, the answer is no. I had it confirmed a few weeks ago by a local AHJ and two plumbers.
Old 5/21/08, 11:41 AM
Jeffrey R. Pope's Avatar
Originally Posted by rray
In my neck of the woods, the answer is now. I had it confirmed a few weeks ago by a local AHJ and two plumbers.
Not allowed by the CPC (UPC). Not now, not ever
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 5/21/08, 11:44 AM
Jeff, do mean soft copper or corrugated flex?
Can you post the relevant portion of the CPC(UPC)
Michael Larson
Hudson, WI
Old 5/21/08, 11:46 AM
rmaday's Avatar
rmaday rmaday is offline
Please Note: rmaday is a non-member guest and is in no way affiliated with InterNACHI or its members.
I'll take marketing for $500 Russel...
the answer is now.
Buzz, Buzz..
RR, "Yes, Rick"
What is, When do you you want your phone to ring?
Old 5/21/08, 1:44 PM
Russel Ray's Avatar
ROTFLMAO. My VRS made one of its few errors, inserting "know" for "no." I manually went and corrected it by deleting that stupid K. I didn't realize that W's could be so problematic.
Corrected my previous post. Thanks, Jeff.
Old 5/21/08, 1:45 PM
Russel Ray's Avatar
Buzz, Buzz..
RR, "Yes, Rick"
I just got in from a rough 7:00 a.m. inspection, so I needed this humor!
Old 5/21/08, 4:30 PM
608.5 Relief valves located inside a building shall be provided with a drain, not smaller than the relief valve outlet, of galvanized steel, hard drawn copper piping and fittings, CPVC, or listed relief valve drain tube with fittings which will not reduce the internal bore of the pipe or tubing (straight lengths as opposed to coils) and shall extend from the valve to the outside of the building with the end of the pipe not more than two (2) feet (610 mm) nor less than six (6) inches (152 mm) above the ground or the flood level of the area receiving the discharge and pointing downward. Such drains may terminate at other approved locations. No part of such drain pipe shall be trapped or subject to freezing. The terminal end of the drain pipe shall not be threaded.
Jeff Pope
Santa Clarita CA
(661) 212-0738
flex copper and LPG kgerhauser Plumbing Inspections 6 4/19/08 9:40 PM
Tinned copper & Copper mnahrgang Electrical Inspections 2 3/13/08 6:21 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? jwatts1 Plumbing Inspections 8 7/29/06 11:50 AM
Looking for comment by Caoimhín P. Connell phinsperger Ancillary Inspection Services & Additional Topics 2 2/18/06 11:22 AM
