I inspected a 2 year old home today. Every visable plumbing joint looked like the attached photos. I have seen it before but not to this extent. I did call it out and advised the client to have a plumber review the issue. Is it a problem or sloppy workmanship?
It looks like the acid paste was not wiped off afterward.
just sloppy work for the most part.....did not wipe the fittings after soldering. If you start to see this on most all the fittings then you usually bet it is a paste and sloppy issue.
Paul W. Abernathy,CMI,CPI,CME National Electrical Code Expert Electrical & Fire Protection Systems Code Supervisor- Alexandria,VA Weekly Live Radio Show :http://en.1000mikes.com/show/the_electrical_guru Weekly Chat on Wednesdays -7:30 PM E.S.T * Get my 13 hour commentary audio CD for the book "How to Perform Electrical Inspections" 2007 InterNACHI Member of the Year |
If the work is that sloppy on the outside, it is that sloppy on the inside. I would be worried about too much flux being applied during the soldering. Reccomend cleaning the joints and monitoring.
Gents:
Thanks for the prompt response. I kind of thought the plumber over did it with the flux. Cheers Doug |
Some soldering info. |
Brian:
Thanks for the info. |
Douglas,
This TEE is definitely leaking. I see water dripping down the side of the black waste pipe... Last edited by dvalley; 10/7/07 at 5:41 PM.. |
Hi Dave:
I saw that as well It was dry- maybe some old glue or whatever- not water Good eye! Cheers Doug |
tneumann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Could even be flux residue....could be a leak, the only one that can tell us for sure is the guy who took the pic....
I've had that flux residue on "me" many a time....but it doesnt' shine as much on skin after you wipe it off in pain...tastes bad too... |
like that commercial for "Workin' Gear" cloths........."have you ever licked mayonase of your finger only to realize it's joint compound?"....."if you can operate a backhoe while eating a grinder and ordering cement on your cell phone "........couple other funny ones too.
| Does this happen offten? | jpassailaigue | Inspecting HVAC Systems | 19 | 4/8/07 1:20 AM |
| NACHI TV waiting for Kenny Hart's flight | dwillis | Miscellaneous Discussion for Inspectors | 10 | 2/14/07 10:39 PM |
| Fire waiting to happen | Tab M. Wilcox | Electrical Inspections | 10 | 2/3/07 5:55 PM |
| Insurance ? What can Happen to YOU ! | phughes | Miscellaneous Discussion for Inspectors | 12 | 4/23/06 1:43 PM |
