![]() Do you check the grounding wire connection at the electric hot water tank by opening up a panel if necessary? |
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Isn't the grounding, when properly done, visible without opening the panel?
No. I do not open that panel.
On older tanks, the wire and nut are not usually visible. I think manufacturers have been making the grounding nut/screw readily visible.
This one is readily visible... ![]() What if the grounding wire and nut/screw is not readily visible? Do ya'll take the little panel off and check? |
Playing Devil's Advocate: Do you check light fixtures to make sure the metal case is grounded.
If it is an older tank I report a new one is needed anyway. These tanks were never intended to function past their typical lifespan therefore they ARE NOT functioning as intended. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
I can't find checking for grounding in the NACHI SOP
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Benchmark Home Inspection Services. http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas. |
Chuck, I agree and am with you on this, but...just in general, how do you comply with Texas TREC 535.229 (c)(3)(F)?
I do not remove the panel.
Greensboro Home Inspection Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas. greensboro-home-inspection.html Raleigh Home Inspection Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas. Raleigh-home-inspection.html BassRumors.com Providing a blog, news, and forum dedicated to bass fishing. |
Yes, if not visible. I also pull the access plates off the elements/thermostats just to check things out. FWIW - I found an arcing wire/contact from a loose connection a couple of months ago....
There seems to be a lot of folks who will not check anything unless it is specifically called out in the SOP. I can't find any reference to verifying ground on water heaters or any other mechanical devices in the interNACHI SOP. I'm curious how many people don't check specifically because it's not in the SOP. Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
If we don't pull out the couch to test the outlet behind it, why would anyone think we should remove an access panel to a water heater? “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
FYI - my mom is 87 years old. She has lived well past her expected life. Do I need a new mother? Should we just write her off due to age. She is in great health. |
But,
is there any significant difference between this: ![]() and this: ?If you do one, do you do the other? |
| PLEASE HELP! Need to change the SOPs, per NEMA | ktarasenko | Electrical Inspections | 76 | 4/19/10 8:15 PM |
| New Washington Legislation Submitted | gdomagala | Legislation, Licensing & Legal Issues for Inspectors | 294 | 2/10/08 1:20 AM |
