Old 8/10/10, 3:53 PM
Bill Smith's Avatar
Bill Smith Bill Smith is offline
Default Cleanout question
Found this CO today. It is installed in the direction of flow, and the pitch of the line is OK, but the cleanout opening is installed on the bottom of the fitting. It would seem that it would be likely to clog, and would flood the basement with sewer water if it has to be opened. Any thoughts?
http://www.SmithHomeInspection.com
SmithHomeInspection@yahoo.com
NY State Lic. # 16000008304
631-434-5200
Need a home inspection in Pennsylvania? Check out InterNACHI's listing of Pennsylvania certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 8/10/10, 4:47 PM
James F. McKee's Avatar
Default Re: Cleanout question
you're gonna get some on Ya when You take out that plug....that's for sure Bill
Classic Home inspections
Jim Mckee
Amherst, Ohio
www.amhersthomeinspector.com
Old 8/10/10, 5:33 PM
Bill Smith's Avatar
LOL - That's what I was thinking too Jim. Thanks for the reply.
631-434-5200
Old 8/10/10, 5:41 PM
lgreen's Avatar
lgreen lgreen is offline
All the solids flowing down the drain would drop into the cleanout. The cap on the cleanout will always be wet and wear out faster than normal. Looks like one stinky mess waiting to happen.
Old 8/10/10, 6:21 PM
Bill Smith's Avatar
I agree. I couldn't find any codes or regs that define where the opening should be, but this arrangement just doesn't make sense.
631-434-5200
Old 8/13/10, 4:48 PM
Banned
Common sense isn't all that common!!
Old 8/13/10, 6:14 PM
That's a government program. It's called "A Drainpipe to Nowhere".
Old 8/22/10, 8:21 AM
Tim Larsen Tim Larsen is offline
PVC "wears out" with water contact?
Tim
Old 8/22/10, 9:22 AM
That's a new one on me.
Clean outs shall be installed so that the clean out opens to allow cleaning in the direction of flow of the drainage line.
Clean outs shall be installed at each change of direction of the drainage system greater than 45 degrees, except not more than one clean out shall be required in each 40 feet of run regardless of change in direction.
Old 8/22/10, 9:32 AM
Terry Clayton Terry Clayton is offline
Would it make more sense to refer to it as a dirty out. Some one didn't like someone that's for sure.
Old 8/22/10, 10:59 AM
Bob Elliott's Avatar
Drum traps under tubs aim down also.
Old 8/22/10, 11:18 AM
And no longer legal to use in Maine Bob. That don't hurt my feelings either, I always hated those darn things. They were made to hold you ring if it fell in the sink.
Old 8/22/10, 4:41 PM
Mark S. Tyson Mark S. Tyson is offline
That was a ****ty installation. LOL
Mark S. Tyson
M Tyson construction LLC
Tyson Home Inspections
Certified General Contractor #1516843
Florida Licensed Home Inspector #1824
Member N.A.C.H.I.
IAC2 certified
Member Florida Building Officials Association
http://www.TysonHomeInspections.com
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
Question for all... Bob Hopton-Jones General Inspection Discussion 9 4/6/07 7:43 AM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/20/07 11:56 PM
