Does anyone have a date or reference point for when a TPRV was required on a water heater. I don't need it for a report, just doing some writing and to cure my own curiosity. Thanks guys.
| Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
...after repeated explosions? InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
Yup, that is the third one I have installed in my home in the last 2 months. I keep putting that cap on the end of that pipe thing, don't know what the heck is goin on!!
I love home-made Rockets |
Okay, now does anyone know when they started requiring an extension to be put on the TPRV?
Did you locate the answer to when the TPR was required? Please share for our education also. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Like it was said above, back in the 1800's when the first steam vessle blew up.
Code dating is not important anyways. All boilers and water heaters simply need a PTR valve.
Appears that it was madated on or shortly after this video in 1939.
http://www.watts.com/mediaCenter/ Click on Educational and watch "Explosions Danger Lurks" 15 min. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Looks like the requirements for the valve were as Marcel said around 39, have not found info as far as the extension requirement. Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network INACHI Awards Portal Want To Exchange Links? What we've got here is......failure......to communicate.....
thanks Marcel thats great info to know
House 2 Home LLC 503-602-1420 HomePros@House2HomeLLC.ORG Protecting Peace of Mind One House at a Time IAC2 Certified IR Certified A favorite place on Google Maps |
| Democrats Enacting Gun Control - I Told You So..! | jmckenna1 | Miscellaneous Discussion for Inspectors | 42 | 2/17/09 1:38 PM |
| No "H" clips? | jbreazeale | Structural Inspections | 7 | 5/17/07 2:28 PM |
