Inspection yesterday in Western Springs, just outside of Chicago. The foundation drain tiles appear to empty into the ejector pump. The house has winterized for 11 months, but I was surprised to hear the familiar sound of water draining into a sump pit, but there is no sump pit, just an ejector pump. The ejector even turned on while I was there. The house was in mid-renovation when it was foreclosed, and I think they converted a sump to an ejector for the laundry room they were trying to install. I know some areas do not allow the draining of ground water to the sewer, but any other reason this is a bad idea?
Michael Merino Merino's Home Inspection & Education Inc. "Not just an Inspection, an Education"SM Phone/Fax 708~535~6057
| Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
How do you know that drain tiles are connected to that 3/4 inch PVC?
Seems like the drain tiles might begin to get a little funky if they are being treated like waste vents. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 2/13/10 at 8:16 PM.. |
I didn't say that the drain tiles are connected to the PVC. I think it was a sump pit that was converted to be an ejector pump for the laundry room that was installed and a bathroom. Instead of a separate ejector pump they are using one pit for both.
Mike this is what I saw ...
The foundation drain tiles appear to empty into the ejector pump. An ejector pump is different so I take it that you were able to open this lid and determine which kind of pump? Ejector pumps have sealed lids ,so is there a bathroom in the basement? That part is fine. What is the small line for? |
The drain tiles do not connect to any PVC, again I am assuming that the drain tiles are under the floor as per a usual drain tile installment. I think it was a sump pit and pump, then the owner converted it to accept drainage from the bathroom and laundry. I am just curious as to what is the downside of this configuration. I know that many cities do not allow the ground water to empty to the sewer line, like the city I live in, but is there any other issues with it. Seems to me that it would not harm anything if left this way. Michael Merino Merino's Home Inspection & Education Inc. "Not just an Inspection, an Education"SM Phone/Fax 708~535~6057
Gray water only, or waste also??? Either way, it should have a venting system. I do not see one in the pic. Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
The vent is there, you just can't see it in the image because it is above.
| Oil boiler combined w/ water heater? | kcheng | Inspecting HVAC Systems | 8 | 6/18/09 6:44 AM |
| InterNACHI course approvals and accreditations exceed rest of industry combined! | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 6 | 4/2/09 3:44 PM |
| BPI / Resnet Combined Training and Blower Door System | jkaylor | Thermal Imaging, Infrared Cameras & Energy Audits | 0 | 2/25/09 4:23 PM |
| FL NACHI at 1,450 members now larger than all other FL trade associations combined. | gromicko | Legislation, Licensing & Legal Issues for Inspectors | 42 | 1/24/07 10:55 PM |
| NW Florida Home Inspectors Association/NACHI combined meeting in Pensacola on Oct 26. | gromicko | Miscellaneous Discussion for Inspectors | 0 | 10/23/06 2:54 PM |
