Old 8/22/08, 12:01 PM
rbrady's Avatar
rbrady rbrady is offline
Please Note: rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Comment on gas plumbing?
What do you think of this? Technically it's not supported properly I suppose.
Certainly does not look professional.
Old 8/22/08, 1:28 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Comment on gas plumbing?
Attachment 23509
Not even getting into the cords or insulation , I would say the pipe was up against the joists at one point and is now loose after not being supported properly, causing it to swing down from its own weight.
I hope you checked for leaks and recommended reattachment to the joists.
Just a guess but , I am thinking something was moved on the outlet or supply side to instigate the dropping , though it for sure was never hung right to begin with.
Old 8/22/08, 1:32 PM
Barry Adair's Avatar
Attachment 23509
It's well grounded??? and the installer wanted to pad the bill with all of those fittings
should have padded it more by properly supporting
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 8/22/08, 1:41 PM
Mark Jones Mark Jones is offline
Wrong type of pipe (galv.) if it is gas it should be black pipe, improperly supported. The cables are not properly supported either. In addition, the pipe has unnecessary connections a sign of unprofessional work.
Mark Jones
Allmark Home Inspection Services Inc.
Serving all of Northern Illinois, Vernon Hills, Libertyville, Gurnee, Fox Lake, Round Lake
Phone: 847 651 2053
E-Mail: AllmarkInspect@aol.com
www.AllmarkHomeInspection.com
Old 8/22/08, 1:46 PM
relliott's Avatar
Originally Posted by mjones6
Wrong type of pipe (galv.), not properly supported. If
I actualy have no problem with galvanized used for gas.
The chemicals in gas which used to break down the pipe are generaly not used anymore from what I have read.
Black pipe is just cheaper.(though I can just see some guy trying to tap in his ice maker with a saddle valve).
Makes for a fun icemaker.CSST may have been a better option.
Old 8/22/08, 1:51 PM
Michael Larson's Avatar
I'm guessing that there was a remodel and that an appliance was moved to a different location.
Galvy for gas would be a no go in my area.
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 8/22/08, 1:54 PM
Jack L. Gilleland's Avatar
Jack L. Gilleland Jack L. Gilleland is offline
I like it. It's decorative and funtional. The creative use of the couplings and nipple to extend one side is inventive. I give it an 8.
In the world view we are all important and our mere existence effects all life.
Jack Gilleland
Home Inspection Services Clayton
Commercial, Multifamily, and Residential
jgilleland1@att.net
Ohio_Commercial and_Home_Inspections
linkedIn
activerain
Old 8/22/08, 2:00 PM
relliott's Avatar
When I was running gas line for Sears , I have had Galvanized recommended to me as a good way to run in ground by Gas Company Employees , so it may depend on when and where.(of course this was before many of the other options came into play.)
Old 8/22/08, 2:03 PM
rbrady's Avatar
Thanks for the input.
It was actually for a gas fireplace addition. I guess the stone mason installed the gas line .
I did remove my mask to make sure I couldn't detect any gas odors.
The wire was cable TV.
Old 8/22/08, 2:16 PM
relliott's Avatar
I bet thats what he had to work with.
Lots of (90's) and no straight couplings.
Old 8/22/08, 3:06 PM
Jeffrey R. Pope's Avatar
Galv is allowed by the CPC. The pipe must be at least 6" above grade - it cannot be touching the ground, regardless of the vapor barrier.
The installation is completely unprofessional, which is enough reason for me to call for corrections.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 8/22/08, 3:57 PM
Christopher Currins's Avatar
Galvanized isn't allowed down here. Also black steel cost 3 or 4 times as much.
Christopher Currins
Certified, Licensed
Proudly serving the Illinois Metro-East
Illinois Home Inspector
Top 5 Tasks for January
Old 8/22/08, 4:14 PM
relliott's Avatar
Black pipe is much cheaper than galvanized, which is why I have used it in many of my art projects, including the car seat I have transformed into a Bar stool and am sitting on right now.
Old 8/22/08, 10:58 PM
Brian E. Kelly's Avatar
Looks like someone got a deal on elbows to me.
Old 8/22/08, 11:15 PM
You're right with the price Bob. That's changed from what is was a few years ago. But that's when it was made in the USA.
Christopher Currins
Certified, Licensed
$99.99 - Dragon Naturally Speaking 9 rspriggs Inspection Hardware, Software & Publications 54 8/21/08 1:15 AM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 3:28 PM
Plumbing Code changes mcyr Plumbing Inspections 0 9/8/06 6:47 PM
A few useful posts - I forget from whom jmichalski Plumbing Inspections 12 3/30/06 10:06 PM
