Are these connectors acceptable for permanent connections?
J. Christopher Weise Upscale Home Inspections of Greater Atlanta - Home, Condo, Commercial Inspector www.UpscaleInspections.com Atlanta Home Condo Commercial Inspection www.atlanta-homeinspector.com Atlanta Home Condo Commercial Inspector NACHI# NACHI07103002 ICC Member and Certification #5319032 Link exchange request form |
http://www.fernco.com/plumbing/flexible-couplings
Jack obviously no. All the structural repairs were a mess. Just checking on the connectors. Thanks.
I used them when I remodeled my bath and had to connect to cast iron. They work great. (or is that a stain I see on my ceiling
Bobby Hamilton Bloodhound Home Inspection Services Youngstown Home Inspection Austintown Ohio Home Inspection Providing home inspections, state licensed termite inspections and radon testing in Youngstown, Boardman, Canfield, Poland, Howland, Warren and surrounding Northeast Ohio areas.
Thanks Bobby and Brian,
I have seen them used before but I was concerned on whether there was a history of the connections leaving a ridge exposed inside the pipe that would hinder free flow and eventually cause a block up. If they have been used and approved for awhile with no problems then I assume they are good. Thanks for the reply. J. Christopher Weise Upscale Home Inspections of Greater Atlanta - Home, Condo, Commercial Inspector www.UpscaleInspections.com Atlanta Home Condo Commercial Inspection www.atlanta-homeinspector.com Atlanta Home Condo Commercial Inspector NACHI# NACHI07103002 ICC Member and Certification #5319032 Link exchange request form |
Some areas prohibit the use of that style Fernco Connector they require the style that has a metal band that covers the whole body. I might also have noticed there where no nail plates to protect the PVC from nails.
I love the bottle jack. That is classic.
Bottle Jack= TN pier
Car Jack= Tn Jack Post Floor Jack= Single wide TN relocation device |
Those cheap Chinese hydraulic bottle jacks are notorious for bleeding off and slowly creeping down, or if you suddenly need to use it to jack up the wife's Ford Pinto "Runnamuck" you have to crawl under the house everytime you need to rotate her tires. Im pretty sure CMUs are less expensive and more reliable.
"War is an ugly thing, but not the ugliest of things; the decayed and degraded state of moral and patriotic feeling which thinks nothing is worth a war, is worse. A man who has nothing which he cares more about than he does about his personal safety is a miserable creature who has no chance at being free, unless made and kept so by the exertions of better men than himself." - John Stuart Mill |
Thank you for your excellent insight Doug. LMAO. Ian Niquette Square One Home Inspection Markesan WI 53946 www.squareonehomeinspection.com Active Rain Network INACHI Awards Portal Want To Exchange Links? What we've got here is......failure......to communicate.....
| Gas Connectors Recalled | ldapkus | General Inspection Discussion | 1 | 3/4/08 8:32 PM |
| Hook 2 appliance connectors together? | jfunderburk | Inspecting HVAC Systems | 6 | 9/8/07 3:24 PM |
| Nice Report on AL Wire Terminations - Enjoy | pabernathy | Electrical Inspections | 0 | 7/2/07 12:35 PM |
| Proper Marr Connectors for Aluminum Pigtails | jskrypka | Canadian Inspectors | 5 | 3/25/07 10:41 PM |
| AMP (Tyco) Copalum connectors | Steven Brewster | Electrical Inspections | 25 | 5/5/06 9:18 AM |
