Can you guys refresh my memory on this cross connection?
I know that when you connect the two together you will usually get corrosion and/or rust as seen here. House was built in 1972 main line coming in is copper as you can see and the rest of the home galv. Troy Farmer Presidential Inspections LLC Chapter President Southern Idaho PO Box 2144 Eagle, Idaho 83616 208-573-5300 http://www.presidentialinspection.com http://info@presidentialinspection.com "He who can, does. He who can’t, teaches" "Where would we be without Teachers" |
cduphily is a non-member guest and is in no way affiliated with InterNACHI or its members.
Galvanic reaction - simply, Galvy + oxygen will slowly corrode the copper eventually resulting in a leak.
rbrady is a non-member guest and is in no way affiliated with InterNACHI or its members.
There appears to be a dielectic coupling at the connection, which should prevent the corrosion. The dielectric coupling may be damaged (e.g. if it was tightened too much) or there could be copper to galvanized steel contact somewhere else.
Thanks guys I love the message board
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
That appears to be surface rust on the outside of that dielectric union, not corrosion caused by the connection of dissimilar metals.
And the proper term would not be a cross connection. That occurs when you have the possibility of wastwater and supply water mixing. This is simply a connection of dissimilar metals (that the dielectric should take care of).
Don't interfere with anything in the Constitution. That must be maintained, for it is the only safeguard of our liberties. Abraham Lincoln www.qualityhomeinspectionsfl.com |
thanks for the clarification (i knew that but my inner brain said right it anyway)
Really soes look like surface rust due to atmosphere. Electralysis hasn't started. You can tell if electralysis is occuring, because the corrosion will be white or gray (usually depending on the amount of salt in air). See if I can find the thread where this horse was beat long after it died.
In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
http://www.nachi.org/forum/f22/deal-killer-24478/
This is not the one I was thinking of, but it might help. In the world view we are all important and our mere existence effects all life. Jack Gilleland Home Inspection Services Clayton Commercial, Multifamily, and Residential jgilleland1@att.net Ohio_Commercial and_Home_Inspections activerain |
| Copper naphthenate & Creosote | kswift | Structural Inspections | 9 | 6/22/11 2:04 PM |
| Copper pipes vs Plastic | ksells | Plumbing Inspections | 19 | 8/31/06 8:27 AM |
| Bathroom Shut-off Valves - Mineral deposits - Do you note them as leaking in reports? | jwatts1 | Plumbing Inspections | 8 | 7/29/06 11:50 AM |
| Looking for comment by Caoimhín P. Connell | phinsperger | Ancillary Inspection Services & Additional Topics | 2 | 2/18/06 11:22 AM |
